Darrel Starr
Plymouth, MN
Here are some shots from Oshkosh showing different approaches to cooling the higher horsepower engines powering SC type aircraft.
1. The "King Cub" built up on our airport KANE, with an 0-390 Lyc has 3.25 wide cheek openings and a 1 - 1.5 inch deflector strip along the bottom opening.
2. The 180 hp Husky has a deflector strip along the bottom opening but the 200hp Husky has a wide movable cowl flap that opens up a large hole in the bottom cowl. It also has two oil coolers but the Husky guys would not open up the cowl.
3. The 180 hp American Champion Scout has a large movable cowl flap on the bottom very much like the 200 hp Husky.
4 The "Backcountry" Mackey SQ2 (Backcountry is the new name for Turbine Cubs) has no side cheeks but does have a big cooler mounted on the firewall with the exit of hot air through a duct exiting on the side of the boot cowl where the hot air will be sucked out. Their more standard Super Cub (the green and white one) has cowl cheeks and a large lip on the bottom cowl opening.
5. The new Cubcrafters Super Sport Cub with the 180 hp engine has a tightly sealed plenum to force air down over the cylinders and on top of the plenum, under the top cowl, is a long narrow cooler that gets air from the plenum. Also there are two scoops in the top cowl.
Wide cheek openings on the "King Cub".
Deflector on 180 Husky, Movable cowl flap on the 200
The Champion Scout, 180, also has movable cowl flaps.
The Backcountry Mackey is VERY innovative, note cooler. Their "1957 Chev" style Super Cub has a large lip on the bottom.
The Cubcrafters Super Sport 180 has a tight plenum and top mounted cooler.
