skywagon8a
MEMBER
SE Mass MA6
Unless you have oversized "bush" tires, the original Scott master cylinder will suffice. Other than that you should match the output pressures with the Clevelands. What do you have now? Picture? As long as they are functional and put out the pressure, it shouldn't matter if they are "oddball".What options for master cylinder/heel brakes for the Cub? It has Clevelands on the wheels.
I've seen the Grove brakes, what others are out there? Not coming up with much in searches.
My CWC had some oddball master and I'm not about to use them.
