O-320-A2B 160hp 1020SMOH. Rear mounted oil cooler. Stock exhaust. Alcor CHT with spark plug ring on #4. At cruise 380-420, can see 470 on a long climb. New baffle seals two months ago and no change. Temps stay the same whether it's -15 in the winter or 80 in the summer. The motor flies 200-275 hours a year.
For the other guys who have delt with high CHT temps, what has been your order of trouble shooting? Seems like there are many options and half of the folks I talk to just say rip out the gauge and run it, it's a cub. Other's say the spark plug ring is useless and read high. Some say drop $2,000 and install an engine analyzer. Seems like guys have luck with baffle ramps, are they worth it. Would an aftermarket exhaust like the AD hotrod help bring the temps down? Anyone seen this after installing a new exhaust system? Should the carb jet be checked? Replace with a bayonet type CHT probe and see what happens? Is this even a serious enough issue to start throwing $$$ at or just keep running it?
For the smart engine folks out there, what are the first indications of high temp damage in a O-320? Exhaust valves?
THANKS FOR THE HELP!
Dan
Dan
