Randy Appling just let me know that he shipped my special Pod. He layed in a little extra material in a few key areas after we talked. His pod is awesome, all carbon fiber, biggest side door (as far as I know), and one of the coolest things is the fact that the entire back end hinges open so you can load long items in through the back rather than having to fit it through the side door - - - How cool is that!
Okay - - - Ready for the next rant (I hope not), here goes. I apologize in advance if I'm stepping on peoples toes here, but I'm completely against loading hundreds of pounds of crap inside the cabin behind the pilot/passengers heads. I know the trend for years has been to build a huge cavernous baggage in the back of the fuselage and I'm just not onboard with that. Hopefully neither me or my son or grandson will ever have to worry about it, but IF there is some event with a drastic frontal deceleration, all that hundreds of pounds of crap is going to try to go out through the firewall. Our Cub had a baggage just like that, the lower section went WAY back and the upper section went all the way back to the trim jackscrew. We've removed it all. When you look back inside the airplane now all you see are tubes. The only thing we're going to have is a heavy duty gear bag attached to the baggage floor/3rd passenger seat base. We'll be able to put a headset, windshield cleaner and so on in it, but nothing else. If it doesn't fit in the gear bag, it doesn't go in the fuselage. That same gear bag can act as the seat cushion (if you're not too picky) for a passenger when needed. EVERYTHING else will go in the Pod. Randy's Pod is so awesome. It's the biggest, lightest, strongest (I believe), most versatile, easiest to use Pod out there. It comes with everything including quick disconnect straps so when you get to your campsite you can remove the Pod and run around light. Very cool.
The other pleasure is dealing with Randy, great guy all the way around.
I'll add more details and pictures when the Pod shows up.
