I have this C-85 driving me nuts. Had problem with stumble at 1400 rpm where it hangs and won't accelerate smoothly past it. Changed to single piece venturi, new pepper box atomizer, new shaft bushing and went through the rest of the carb and it does exactly the same thing. It's on a PA-11. No intake leaks were found. It will transition smoothly with the carb heat on, which is telling me it's slightly lean. With carb heat off, using mixture it will gain slightly on idle and high rpm. The problem area is just in the starting area of 1400 -1700. Any unusual things that I might look at? Mags are just redone and retimed which made no difference. Last thing I noticed is the bracket element is dry to the touch, and the carb heat flap is not going completely to full cold. Any ideas are welcome.
Ron
Ron
