soyAnarchisto
MEMBER
Boulder, CO
Very familiar. I have met the glider pilot who was in tow.
Any pilot can become distracted - and you have to do some multi-tasking even to change the radios so the fact that it was a Cirrus with a glass panel. Obviously none of the 3 pilots were aware of the others. I see this ALL the time here. With ADSB - the Cirrus pilot would have been FAR more likely to be aware of the presence of the other aircraft in close proximity and in all liklihood heightened his looking out the window.
You cannot blame all mid-airs on the pilots not looking out the window. With ADSB planes broadcast their position more frequently and more accurately - and this is only a good thing. Even if you don't adopt any glass inside your plane - having your whereabouts known to others is FAR better than without. There are many situations where you can't see other planes: colors like white are hard to make out against sky/clouds/overcast, sun glare, wing orientation high/low etc... Believe it or not - planes are really hard to see - even when you know where they are - or where they think they are on the radio.
It is lunacy to argue that just because people may have more electronics in their aircraft we should not adopt more accurate position reporting technology. Under the auspices that with less technology people will be forced to look out of the plane? That is just plain ridiculous.
The problem with 2020 ADSB is that it doesn't go far enough. Every thing 400ft AGL and above, from part 103 to model airplanes, to drones, to gliders and no electric cubs should have been required to be on all the time. Maybe someday we will get there.
Here's another one - happened more recently - one of the pilots was a DPE - very accomplished pilot - and the other plane had a CFI. Neither plane had any electronics in it.
http://www.timescall.com/ci_21434044/agency-faults-pilots-after-fatal-midair-collision-over
