I'm trying to use an Atlee Dodge wing jack for a wheel change on a Carbon Cub. I've attached some pictures of what the jack looks like and what my strut and fairings look like.
Specifically I want to know what part of the wing strut I can attach the top of the jack to so that I can applying lifting pressure without damaging anything. The U shaped metal attachment at the top of the jack is not the same shape as the strut fairing. Is this jack (or at least the attachment) incompatible with this airplane due to this fairing or is there some way to use it? I asked if it was compatible when I ordered it. I feel like the jack will just ride up into the aileron cable pulley if I tried to lift the jack with the U shaped attachment making contact with the wing strut.
EDIT: I can't jack the strut by the gear/axles for this job, it involves working in the axle areas to put skis. I appreciate all the suggestions for that but it's not feasible, and I have covered gear. I realize that it's far and away the most popular way to jack up a cub, but it won't work in this case.
