Marty57
PATRON
Nipomo, Ca
I'm finishing up the cable runs in my wood 2+2 wing and I made some cable guides that the aileron cables will pass through at the root rib. The guide is one piece rather than split like the Piper fairlead; one on each side with AN3 bolts going through (see attached picture). The hole through the root rib is 3/4" (not the small hole to the left of the guide) and the opening in the guide is 1/2". The cable's won't be directing or changing the angle of the cables in any way; they are just for protection of the structure where the cable comes closer than 3/4" to any structure. My question is regarding building up the aileron cables. Will I first run the bare cables through the wing and than form the swage on both ends of the cables? The guides have the same 1/2" opening as the Piper fairleads just not split. Do the cables have loops on both ends or ???? Being unsure of how the cables run I'm a little unclear about use of guides and fairleads. (I could split these guides in two pieces if necessary) The same issue comes when running the cables through the pulleys in the wing. A 1/8" cable will run nicely under the pulley cable guard without any ends. With ends on the cables all the pulleys need to be removed from their cages to install the control cable. So what is the best way to proceed. Thanks
Marty57
Marty57
