wrightmij3
St Joseph, MO
I’m building up a Stroker conversion for my J-3 with a 65. I found a C-85 certified engine and have started building up the Stroker. I have had the case and camshaft inspected as well as the lifters by Central Cylinder in Omaha. I had a serviceable O-200 crank 0-200 rods also inspected. Putting it together all proceeded well. Case was closed and everything rotated well without problem. I When I put the cylinders on and rotated the engine on the engine stand there was interference at number one cylinder between the piston rod cap and the camshaft between the lobes. I haven’t found any reference in the threads I have searched to this problem. I called aircraft specialists and they weren’t helpful. I called Dons dream machine and they were not very helpful since I didn’t buy their STC. Has anyone had this problem? All the rod bolts are new. What is the solution?
