wireweinie
FOUNDER
I'd like to add a couple of things about the magnetometer wiring. If you are running LED nav/strobe lights, those lights PROBABLY will not draw enough to effect the readings from the magnetometer. But, if you run pitot heat and/or landing lights (especially incandescant lamps), there is a good chance the current draw from these will change the magnetometer readings. To prevent this from happening, keep the magnetometer wires separate from all other wiring. As Bill pointed out, there are places like the windshield post where the wiring simply cannot be spaced apart. So keep the wiring separated when you can and in the tight spaces just don't tie the the mag wires into the bundle with other wiring. Also, I've had good luck just 'gluing' the wires into place on the spar using RTV. Tape wires into place and add dabs of RTV. Pull the tape once the RTV sets up. Still allows you to pull the wires out if needed, in the future.
Nothing wrong with the mounting bracket in the pics, but I agree with Bill, I don't like extra holes in the spar. I prefer using a bracket between the ribs. Which ever way you decide, make sure you use the correct hardware! It should not need to be said but DO NOT use ferrous hardware. Garmin instructions even say to not use magnetic screwdrivers or electric drill motors when installing or maintaining these items. While Garmin says stainless screws are ok, I still use brass screws nuts and washers.
