Brake lines for Atlee Heavy Duty Extended Gear
I'm not sure about the science behind it but I worked on a Cessna 180 with -3 lines. It was extremely sensitive to locking up the brakes, I had to introduce a lot of air into the system to make it function properly.
I'm thinking 16- Bravo is right, somehow it works better. Anybody else have -3 lines on their brakes?
Older thread but does anyone have anything to add as far as one piece brake line size and length? Kicking around the idea of going to a -3 stainless braided line on Atlee 3" extended gear w/Steve's boosters. 66" length was thrown out earlier? Yet to measure existing length.
Measurable? If so, it is a good argument against full length flex lines. I sort of doubt you could feel the difference.
Thinking of a -3 line instead of a -4? Think about it. The master cylinder is matched to the brake cylinder as to volume requirement which is very small. Since the volume needed is small there is no need for a large diameter line which would allow more flow without resistance. Your only concern is the transfer of pressure from one end of the line to the other. Use the smaller diameter line for weight savings.
Great points. I appreciate all the responses and links. As concious as I am about weight, that kind of all went out the window after installing 35"s and a belly pod. 10lbs off my a$$ would be the best weight savings measure. I'm guessing that the weight savings and pedal firmness between the -3 and -4 line is probably negligible given a properly functioning system. Every little bit helps, however, especially when stopping 35"s.
