Darrel Starr
Plymouth, MN
I just installed a manifold pressure gauge in my SC with an 0-320 160 hp (Leading Edge exhaust) equipted plane. I believe the MP gauge is accurate +- 0.5 in Hg. I have been surprised to see only about 21 in.Hg at 2500 rpm, 2000 ft. 60F with 28.5 in. Hg showing on the gauge at 900 ft before start-up. Then last evening, I noticed that at initiaal climb out at 2500 rpm, full throttle at about 65 mph it was indicating 26.5 or 27 in. Hg. So I think the gauge is reasonably accurate. Also, recently we were flying alongside Doctor Randy in his very similar 160 hp SC indicating the same airspeed at the same engine RPM so all seems well. I am just a little puzzled by the relatively low MP readings at cruise at 2500 RPM. That turns up on the Lycoming charts to be aroud 75% power or a little less.
Now I do remember some comments published by Roger Borer to the effect that the long prop (82/44 in my case) would require higher RPM in cruise but in searching back threads I have found nothing definitive on this subject. So can any of you shed some light on this subject? Since N18SY runs fine right along side of Randy's SC, I think the engine s running fine and I'm reasonably confident that the gauge is +- 0.5 in. Hg so is it normal with an 82/44 Borer prop at 2500 rpm to be running at 21 in. Hg and about 75% power? I would have guessed that 75% would have been more like 2400 rpm.
Do any of you (other) anal nerds have a manifold pressure gauge and a fixed pitch prop? Especially a Borer?
