Wayne Vance
I have built a Wag Aero Sport trainer patterned on a PA 11 with modifications of a PA 18 tail, gear, struts and wing tanks. The airframe is nearly complete and I just mounted an O-235 with a standard Lycoming cub PA 18 mount, and discovered the engine oil filter sits just above the boot cowl. It is easy enough to change out to a straight filter screen and the cowl would clear (just) I measured a PA 18 firewall and discovered it is about 3 to 4 inches taller than my (PA 11). Has anyone encountered this problem and is it really a problem? I still have to construct the engine cowl so it's anything goes at this point or do I need to back up and rebuild the entire firewall/boot cowl. Second question is which nose bowl is right? I don't believe the PA 18 bowl will work under this configuration because it would make the entire engine cowl slope up from the boot which would look and be terrible. I realize it's a long question but thanks for the help
