RVBottomly
I was thinking the same thing, but then I thought of a good reason to push the stick forward. It's to position it out of the way when you unlatch your seatbelt upside down....
If you’re slick enough to remember to do that while you’re sliding upside down, I bet you’re slick enough to not get it on its back to begin with.If the plane is sliding along on its back with a broken vertical, you want the TE of the elevators to have positive AOA.
Beringer has "legacy" geometry - Beringer suspension will have the axis 3 inch closer to CG - am I correct?
It's actually the increasing lift from the wings as the speed increases which is lifting the nose.Same thing happens in reverse when taking off. The pressure in the struts is raising the nose during takeoff.
Yes, the EX/FX3s come with 3" extended and 3" forward gear. The 363 engine and the constant speed prop tend to move the CG more forward thus putting more weight on the tail with the 3x3 gear makes them less prone to going on their back. They like to 3 pt. or a tail low wheel landing. Have flown several SSs that were very light on the tail and tippy when you used brakes.Can somebody please clarify this for me..
My understanding that the standard EX-FX3 gear is 3x3 gear (the axis of the wheel is 3 inch forward compared to the legacy gear).
It makes tail heavier in the roll but reduces chance to put the plane on its back.
Just for reference sake: When comparing any style of gear to spring steel gear, So folks can get a feel for how far this actually
goes back in years. A cleaver builder of Cubs(Tinny Headland in Illiamna Ak) started putting C172 and later C170
Gear legs on 18's in early 1980's, He built some for other guides, I got to fly one in mid 1980's, that was built for Bob Tracy of
Non Dalton, one fall I worked with him, my accesment of that gear, jumping back and forth from my Cub on standard gear: Was it was certainly impressively smooth
In really rough tundra, and over big rocks, on the old 30" Airstreaks. It very well could have been tryed much earlier; somewhere else? But the point being, there is certainly nothing NEW about spring gear on a Cub, So realistically, Cub Crafters are certainly very late to that party! By at least 30 years.[emoji2955]
I'm concerned about flying my supercub with the legacy gear after reading this thread.
I'll take time tested old crap over new and improved any day
get out of the way.
We seem to get alot of folks who show up here voicing opinions and ideas. It would be nice to know something about them other than a screen name. People rarely fill out their profile.
There are no good seats at a tennis match.
Normally it’s good to at least get the cross hairs on the target. Shooting from the hip is rarely effective.I'll take time tested old crap over new and improved any day
glenn, i sortve like my t3 tailshock.![]()
Beating a dead horse.... except this one appears to have got back up....
