Badlands STOL Kit
rv6ator
MEMBER
Sherman, CT
Would appreciate any PIREPS on the Badlands Stol Kit. Installation, performance etc:.
This is the cuff kit Clint is producing, yes?
(subscribing to topic because I am curious myself)
Thats the pretty much the same as the Crosswinds STOL cuff thats been out for 50yrs nothing new there, Hahahahahaaaaa
I like the look of the Badlands compared to the Crosswinds, which I have. Have not flown the Badlands. I would do the Badlands on an experimental in a heartbeat.
There is a thread with the profile of the Badlands cuff and the second revision is longer than the Crosswind STOL cuff. I believe Clint got their after building his own Cessna style wing for his Badland Traveler.
The “Badlands Stol” cuff isn’t really a crazy invention honestly. Even the name isn’t very original as my generation seems to thrive on catchy words and letters like X, ass, bad, extreme, R ect. It’s very similar to the sportsman kit for the Cessnas, and to some degree is an adaptation of that idea to a cub wing.
it adds 2” of chord to the wing which is significantly more than the crosswinds stol. Of course I think I’m onto something, but so does everyone else who’s had an stc for the cub
The Sportsman on a Cessna extends the glide, lowers the stall speed, and improves slow flight reserve. Sealed ailerons offer better control. Should provide similar for the Cub. Not sure about the effect of VG's added to the package, or an upper wing stall fence. It's got to help.
curious as to flaps, no flaps, gross weight, etc has a bearing on the positioning or is there one spot for all?
There’s only one position for the foam profile blocks to go, and they sortof “key” into the existing leading edge profile.
not sure if that answers your question though
i guess what im wondering is if more droop or less makes a difference for different plane configurations? is that the right way to say it? like if you draw a straight line from the bottom of the wing forward how much below that line helps or dosent help? or is there one dimension that works for all.
here is an idea of the cuff shape.
Installed on a set of Javron wings. Not covered yet.
Did it last march while waiting for more parts for my 4S. still waiting....
I believe a smooth continuous roll to the upper and lower cuff surfaces helps airflow. Air doesn't like quick changes in surfaces (opinion), and flatter or quick turning/small radius surfaces can create some turbulence behind the leading edge. I flew a Crosswinds (with a flatter upper and lower form on two Cubs and a Citabria), and a Sportsman (more rounded like this cuff) on a C-185. In rain the beads rolled smoothly over the Sportsman, while some would linger on the Crosswind's flats. Not sure why, plus what else is there to do between here and there in rain to stay busy?
Some questions about the foam ribs. As Clint said, they pretty much line up with the existing airfoil one way.
There is a small amount of play. Used a string end to end and went through it about five times and got them all lined up.
Sorry for the dual image.
Tom
View attachment 66921View attachment 66921
Tom
What cover system are you using? I’m waiting on my Javron kit, bought the Badlands kit a few months ago. I’m hopeful the Stewart system glue will hold down the fabric so that I don’t get any bridging.
Ortex. Still not covered.
Drove to Jays place last November to pick up my engine, then spent a month or so building up the cowling.
I am just now finishing electrical install. I am planning on putting it all together to make sure everything works pre cover. Hopefully I will be covering next month.
Tom
