And so it begins
Have you considered the flammability of the resins you are planning to use with your carbon fiber? Long ago when we were certificating the Twin Bee, we had to prove to the FAA that the fiberglass cowls would not support combustion. The test involved aiming a blowtorch at the vertical section of cowling until it was burning. Then removing the blowtorch with the fire self extinguishing. Initially, using convention resin materials, the burning continued. This required adding a third chemical to the resin mixture which caused the finished product not to support combustion. The FAA was only concerned with the resins used surrounding the engine compartment not elsewhere on the airplane.
Perhaps the resins available today do not support combustion? I don't know. Whatever you use, it would be a shame for a close exhaust to ignite the resins and continue burning.
You could also use metal tape on the carbon where it is close to the exhaust or a shroud around the exhaust.
I used pink foam from home depot for my smaller, lower cowling but painted it with two coats of water based latex paint before the bondo. That prevented the bondo resin from melting it. Epoxy resin will not melt the pink board foam; however.
I had considered doing exactly what you are doing with the expanding foam. Please keep us posted with lots of updates and pics!
I laid up the carbon fiber air filter tunnel and dome. Thought it would look better with a beaded lip so I glued a piece of .25” foam cord on flush with the inside of the lip. Then faired the outside with micro bubbles and covered with a couple layers of carbon fiber.
The cowl is ready for lay-up but I’m searching for a suitable resin. I’ve been using West Systems 105 but it won’t take the heat without getting soft. Flammability is also a concern. If anybody has a suggestion I would appreciate it. I don’t have the ability to post cure in an oven…the mold is formed on the plane.
Back at the project after almost a month off. I did the lay up on the lower cowl and should have the upper sections done this week. Four layers of 3K twill. Shark gills will be added later. IMG_6973.webpIMG_6974.webp
Pulled it from the mold and did an initial trim. The rest of the cowl will be laid up tomorrow.
Turning out ok with a couple spots that need a little fixing. Once those are addressed I can make the cuts for the hinges.
Modified the nose bowl by making the inlets slightly smaller on the prop flange side and making it fit the profile of my spinner. Since the center area will be covered by the spinner I trying to come up with a method to attach the upper and lower sections of the nose bowl once I cut it in half. If anyone has come up with a good solution please share photos. Thanks.
What did you use for a mold to get the shape for the top of the nose bowl?
First, I bonded into the cowl openings a flat sheet of carbon fiber, traced the final shape I wanted the opening to have and used a die grinder to cut the shape. Then I just taped a plastic sheet around the area I wanted to modify and poured in expanding foam. Once it was set up I shaped it with sand paper. I traced around the spinner base on a piece of cardboard and put that on the prop flange and traced around the cardboard onto the foam and nose bowl to get the final profile.
I have a CubCrafters split composite cowling and I’ve only split it once for maintenance. I better like to remove the prop and the complete cowling to have access to everything when needed.
Mine has 1 upper part that goes over 1 lower flanged part, with screws and nutplates. Machine Screws and 2 aluminum threaded vertical flat bars near the prop spinner.
iRsAaNwgfX3eZ9uM8
Thanks Oli.
The issue I have is the spinner is rather large, 14 3/8” diameter. I was planning to do something like you have but realized the screws would be behind the spinner and thus not accessible without prop removable.
I would fabricate a fibergalss flange to join the two halves. First I would plan on a method to mate the upper and lower parts together before I make the big cut with my bandsaw. for example, for temporary mating I envision a 2" wide strip of .025 Aluminum match drilled and clecoed to the outer cowl surface over where the big cut will be made. Actually, I like four places where the cowl can be re-assembled...the outboard and inboard areas of both sides.
Then I would disassemble it, and cut it on my band saw.
Then I would put apply a mold release product to the upper cowl part along the seam. Use smooth 3m packaging tape for this mold release.
Then I would reassemble the two parts and apply epoxy impregnated fiberglass cloth 2 or 3 inches on both sides of the seam.
I like rutan 7725 bidirectional cloth. One layer of cloth has about the same strength as .010" thick of Aluminum. SO if you migh twant the strength of .060 AL you might use 6 layers of this 8oz cloth. Let this cure up, then disassemble the pieces. The upper part of the fiberglass will match the upper cowl, but it will pop right off because of the mold release packaging tape. Lastly, trim the oversize flange to a desirable shape and size. Sand the edges smooth. Match drill the two pieces through the flange and install your fasteners. Maybe tinnerman clips?
Thanks Oli.
Insert the fasteners which are behind the spinner from inside using either screws or AN-3 bolts depending upon which type of tool works best. Attach plate nuts outside the cowl hidden behind the spinner.
I split the nose bowl. It will be held together by two screws on each outboard section (where you can see the pink silicone pull from the Click Bond nut plate) and two pins on each side of the center section. The sections have been sprayed with Eko Fill for UV blocking and primer. Paint will wait until I’m ready to paint the wings.
Starting to come together. I should have the rubber baffle seals all cut tomorrow.
Did the smoke test this afternoon…no smoke so far. The AV30 sitting on top of the GPS navigator goes in the open hole in the panel. Nothing is screwed into place so some are a little crooked.
Finally picked up my prop and mixture cables. Drilled the instrument panel and installed the firewall penetration ball fittings. I labeled the knobs on the instrument panel. This was the last panel lettering to be done. Now the panel gets removed and clear coated.
I have an Advanced Panel ACM, similar to Vertical Power. Everything plugs into and is powered through this box. Positive and negative terminals are labeled with maximum torque values and there are large red warnings on wiring diagrams specific to the negative terminal torque. Well, wrench monkey…me…snugged the negative terminal a tad too tight connecting it for the final time and snapped it off. Ugh. Advanced Panel has been great to deal with throughout. I emailed them and they apparently sell their stuff to many ham handed folks so they will repair the first broken lug free. I’ll be driving it down to their office tomorrow and picking up an inch/pound torque wrench on the way.
Panel is back in business. Still having issues with the Avidyne not picking up a GPS signal. I suspect it’s a bad antenna but have to do a couple more tests before trying to get it replaced.
Hooked up my tail light/strobe a couple days ago. Wow is that bright!
Taking a few days off the cub project to get the annual done on the other plane. No beefs with it so it should go fairly quick.
Have you tried taking it outdoors where it can see the satellites? My Garmin works in the hangar without an antenna, the Avidyne may not.
I haven’t tried that. Winter weather here is a bit on the wet side so finding a dry window of opportunity is problematic. Additionally, the dolly it’s on wheels but there’s a small lip at the transition to the concrete parking pad. Once I put the gear under it it won’t be a problem.
The Dynon picks up a signal just fine inside and its antenna is 20” from the Avidyne.
Had a nice day and a few friends to help push it out and back in the shop. It took a couple minutes to figure out it wasn’t in FL anymore but it did hook up to the satellites! Pushing it back into the shop the position was lost as soon as the antenna crossed the shop threshold. Happy it works but surprised at how little it takes to interrupt the signal reception.
I recently discovered my carbon fiber panel is conductive. Don't laugh...., but I swapped the original aluminum panel out 10 years ago, and somehow in all that required work, never touched a hot wire to it until a couple weeks ago. It surprised me, I guess I mentally lumped it in with fiberglas, which, come to think of it, MAY be somewhat conductive but I've never checked, but if asked, would say no. Then I though of carbon brushes in motors, and put two and two together! No harm done or anything, learn something new every day.
That's interesting. When Wireweinie comes back from his sabbatical perhaps he can opine on whether this would be a good material for an antenna ground plane? Would it have as good EMF reflective properties as aluminum?
