And so it begins
Stitched up a leather boot to cover the hole in the glare shield.
Windshield installation almost complete.
Pealed the paper off the skylight.
Reinstalling the kick panels…hopefully for the last time.
The 4130 is all powder coated. The floorboards and a few interior trim pieces have an anti-chafe tape barrier between them. The screw holes in the floorboards have nylon inserts and the screws have nylon washers.
This looks substantial with a well done latching mechanism. I am curious. Carbon fiber is very strong and stiff when properly used, as it appears to be in this case. Why did you decide to use four latching locations rather than just two along the bottom? Was it "just because I wanted to."? Nothing wrong with that. I would think that with the stiffness of the door, just two along the bottom would be sufficient. Or have I missed something?
  • Like
Reactions: bda
Two would probably have been sufficient. An engineer friend recommended two also. So it was mostly just my preference. The door is plenty stiff.
I have not been following the thread ... is the door replacing "structure"? tubes?
looks really nice!
looks really nice!
Door is just filling a big hole. Structural analysis done on Solid Works by an aeronautical engineer. Fuselage beefed up to accommodate big hole. 🤞Think Maule or Bearhawk…bigger hole on those.
looks really nice!
cfc117b5-d4d3-42d0-b4ea-c7eafb029088-jpg.47942
He moved the upper longeron to the top of the fuselage. I wondered the same thing.
