Almost Killed Myself With Corned Beef PSA
OK - I did the sausage & cabbage deal we've talked about. I couldn't find Penrose and did some checking - the factory burned down for the big sausages like I remembered, though you can still find the little ones. This is what I could find readily that duplicated it (and definitely was in the gas stations here at that time):
OK - that's done, the recipe and putting it together in a pressure cooker (we use an Instant Pot which cooks with 10 pounds) minimum water to operate in ours is 2 Cups:
1 cabbage cut into quarters
Put as many peeled potatoes on top of that to cover
6 sausages on top of the potatoes - you could put 4 - but don't put any less
4 crushed chicken bouillon cubes sprinkled on top of the sausages (the little ones - not those huge Knorr cubes)
He put 2 sticks of butter on top - but he also had a massive stroke and died at 64 - so I cut that to 1/4 stick cut into pieces and covered the sausage
1/4 t pepper 1/2 t salt.
35 minutes and let the pressure release naturally
The above doesn't show where I put the butter - slathered that on top of the sausages, they transferred the red color to everything else.
Definitely turned the potatoes and cabbage the red color (and some was bright red) I remember as a kid. Connie said it had great flavor and I agree with that. We also agreed the sausage was disappointing, but that may simply be because it transferred all it's flavor to the cabbage/potatoes. Might be why I was told to eat the cabbage & potatoes as a kid and wasn't allowed the sausage (and they could have been Penrose Red Hots).
If we had used 2 full sticks of butter, that would have really made a rich sauce - but my health just isn't up for it.
If there's enough liquid floating oil in the dish the excess oil can be removed via absorbent pads. The kind used to clean up oil spills. Just cut off a piece and briefly dip and swirl it into the cooker. Works.
