BENEFACTOR
I went down a rabbit hole this morning after watching the video posted below from Alaska Gear Company and would like to here from someone who has used these. Sean says in his video that they are lighter, make more pressure and are cheaper. I have Dakota Cub master cylinders on my Super Cub and have installed a lot of Steve's Vented Brake Boosters.
I like Dakota's because everything is new and I install these on rebuilds because I have access to under the floor. If you buy Dakota's kit for $1638.48 you get inspection plates, grommets and adjustable brake rods which helps gain access to the master cylinders and gets rid of those non adjustable welding rods to inner connect the front and rear brake pedals. I really like the adjustability of the DC brake rods and the high capacity brake reservoir, check the indicator in the fill hole at annual and go. $1470.48 for just the two master cylinders.
I like Steve's to replace those pesky non-vented master cylinders that I can bleed in the morning and can't push the airplane out in the afternoon warmth. They fit on the factory Scott frame and it is a pretty easy upgrade especially when using NAS1352-08-8P Allen head screws to install them. Nice big reservoir that I only have to look at at annual. $890 for the pair of master cylinders ready to bolt on your Scott frames.
Alaska Gear Company is using a 13/16" piston diameter and they say you get more pressure and a progressive feel. I know Dakota Cub uses a 1" piston and I believe Steve's is 1" as well. Not sure how you get the more progressive feel, the stroke is the same, limited by pedal travel, I can understand more braking pressure but I have not had an issue with enough pressure even when I was on 35s but I hear some folks do. Will be interested to hear PIREPs on these new brakes and how the feel and perform differently than what is out there.
Dakota Cub Master cylinder with extended reservoir 1.5 lbs each.
Steve's brakes with Scott frame and pedal 1.8 lbs each.
Alaska Gear Company posts 1.08 lbs each for their new brake master cylinder.
Dakota Cub $1470.48 pair or #1638.48 for the kit
Alaska Gear Company $1375 a pair
Steve's Brakes $890 a pair
alaskagearcompany.com
dakotacub.com
High-Pressure Brake Master Cylinder
The High-Pressure Brake Master Cylinder features a 13/16” diameter piston, providing superior hydraulic pressure with minimal foot pedal effort. This smaller piston diameter generates higher pressure, resulting in a more controlled and progressive brake feel, enhancing pilot control and safety...
Steve's Aircraft Vented Booster Brake
General Aviation Maintenance Specializing in single engine fixed gear. Owner assisted annuals. STC Developments Fabric Specialist
www.stevesaircraft.com
Extended High-Pressure Brake Master Cylinder Assembly
Extended high-pressure brake master cylinder assembly; for aircraft with 26" and larger tires; Note: J3 s/n 10339 and higher unless previously approved with Scott system. Sold as a pair. Please call or email if you're needing only one.
