My EGTs had a large spread on the carb, to now a very small spread on the injection (when it's running right). I understand the point behind the test to get real data about the mixture differences between cylinders, as there are many reasons the EGT numbers are not accurate when compared to each other directly, but it's very obvious the mixture is much closer with injection vs. the carb right off the bat. When it's happy, the spread is very low, when it starts running poorly at low throttle, the EGT spread opens way up from 1/3 vs cyls 2/4. Fine tuning the injectors isn't going to fix whatever is causing this issue that has come and gone now. If it had been this way since first start, I would agree that it may need some adjusting, but when it's right, it runs really well.
If I can get this issue solved, then I will definitely perform this test and see what fine tuning it needs. There is something causing a very obvious change. I got a few hours of it all working correctly after installing the injection, and about 30 min yesterday before it went haywire again.
It's like a switch is flipped.. it goes from smooth, even egts, when I advance the throttle quickly with it already leaned for peak power on a climb it revs up smoothly... once this happens, it starts periodically misfiring, sometimes a little puff of black smoke, big egt spread, can't advance throttle without it stumbling (have to richen mixture or move throttle slower) etc. Once its rev'd up, it runs fine, EGT spread is tight, max power is there (same rpm on climbout) But down low it's not happy.
