supercub83a,And no part 91 operators have to comply with SBs.
If the question was more about figuring out what ADs could apply, then Im in the same boat. I have an aerosport io-375 too. It is superior cylinders and a superior case with a continental crank so I think researching the applicable ADs and SBs will require extra effort. If anyone has an easy way Id be interested.
Great info, thanks for the reply.My io-375 has 9:1 compressions, superior cold air induction, e-mags, and the hartzell trailblazer 83” prop. Its the only engine that I’ve had on this plane. The plane weighs 1274 with belly pod and slats on 35s. Before the slats and pod it was 1225 (with 8qts of oil in the sump). It has an amazing amount of acceleration, everyone that rides comments on it. Before slats and pod at 75% power and 3500ft it would do 120-125 indicated. 65% would get you about 105-110 and 55% about 95-100. Thats on 35s. Fuel consumption at 75% was over 12gph but at 55-65% and lean of peak im getting 6.5-7.5 gph.
My last cub was an o-320 160hp, with a borer prop pitched to 82-47. It was on 31s and weighed 1191 on wheels. Previous owner had pitched it to a cruise prop, but it would still get over 2400 rpm static. At 2400 rpm it would cruise around 90-95 and burned a little less than 7.5gph. Its harder to have more precise and accurate numbers for it because it lacked the instrumentation to measure.
Conclusion is that the io-375 lean of peak on 35s gets slightly better fuel economy than the o-320 did on 31s for the same indicated airspeed. Overall fuel consumption is higher on the 375 (burns a lot more down low and rich). The acceleration on takeoff I can only measure subjectively, but it seems to be about 50% greater than the previous cub despite that cub being almost 100lbs lighter. The plane is; however, very nose heavy. Not a problem if you fly with tons of gear, but maybe not the greatest handling when lite.
The engine prop combo was by far the biggest upgrade made from the last cub. Slats were the 2nd biggest. G3x system and modern suspension tied for third.
Flying a sub 1K carbon cub with the redesigned ailerons and a 180horse stroker engine is probably the most joyful flying plane I have flown. I think at light weight it would outperform the heavier/higher hp cubs. I really cant imagine it hauling half a moose out of a shorter, rougher strip than the SQs and o375 cubs with massive flaps and slats though. I may go the ultra light cub route on the next build regardless, maybe a carbon cub or another javron. That may hinge on cubcrafters new ELAS system availability on the carbon cubs, very interested in that system.83a....next build a sub 1K Cub with 160. Feel the power in a light frame as we've talked for short ops?
I would like to know more about this airplane.N
The FAA places no mandate on an engine for an experimental aircraft to conform to a type certificate. Yet AD's and SB's are good information for the EAB builder to consult. Is anyone in authority thinking your engine must conform to a type certificate?Can anyone advise whether my experimental aircraft powered by an Aero Sport Power 0-375 engine must comply with all Lycoming o-360 AD's and SB's.
It was an EX-2 I flew at the factory when the EX2 was fairly new. Flew it about an hour and did 8-10 landings in it. Had the CC-340 engine. Claimed the weight was 9** something and 180hp. I do know that it handled and performed like none of the cubs I had flown up to that point. I still think my current cub would out lift it, but it doesnt handle as nicely. At least to the best of my recollection….I would like to know more about this airplane.
How’re your CHT’s?My io-375 has 9:1 compressions, superior cold air induction, e-mags, and the hartzell trailblazer 83” prop. Its the only engine that I’ve had on this plane. The plane weighs 1274 with belly pod and slats on 35s. Before the slats and pod it was 1225 (with 8qts of oil in the sump). It has an amazing amount of acceleration, everyone that rides comments on it. Before slats and pod at 75% power and 3500ft it would do 120-125 indicated. 65% would get you about 105-110 and 55% about 95-100. Thats on 35s. Fuel consumption at 75% was over 12gph but at 55-65% and lean of peak im getting 6.5-7.5 gph.
No issues with oil temps, as we have dual coolers fed by a ram air scoop on top of the cowling. Here’s a side shot of the full cowling
Your upper safety cables tab should be attached at the gear leg bolt tab. Not the Cabana V tab.This was before, then after adding the cowl lip. I only have one oil cooler and temps stay around 180-190 in cruise. I just thought of something that also might account for some difference, I manually retarded the timing on the EMags by a couple degrees.
Good point. Unfortunately, that is the way Legend fashions the lower cowling piece. I’ll fab a temporary wedge and attach to see if it helps.You may have better outlet airflow if that cowl lip was angled back more. 45 degrees or so. The way it is now, the air flowing around the outside swirls up behind the lip creating an "air dam". This could actually restrict the outflow of the engine cooling air.
When Cessna supplied the optional belly pod on the 180/185s, they also installed cowl flap extenders. On one plane (I think the Cessna 140) there was a rolled (2" +/-) piece of aluminum mounted to the bottom of the firewall which helped produce a venturi effect to suck more air through the engine. I've also seen lips mounted to the side cowls to pull more air out that opening. It was ugly though.Good point. Unfortunately, that is the way Legend fashions the lower cowling piece. I’ll fab a temporary wedge and attach to see if it helps.
There’s no doubt that the 4” deeper experimental cargo pod disaffects the cooling and cruise speed. Were I to do it over again, I would replace with standard pod.
Already fixed, realized I did that a few months ago.Your upper safety cables tab should be attached at the gear leg bolt tab. Not the Cabana V tab.
You ever try lead shot in the horn at the bottom of the rudder to help with the extra weight on the nose? I've heard you can get approx 7 lbs in the aluminum fork at the bottom of the rudder.... or, potentially up to 6 lbs of antifreeze in a baby bushwheel without losing cushion? I took off a 320 and put on a IO-375 and a CS prop and gained enough that I run out of elevator without power. Few perfectly before adding the extra weight (even loaded with a passenger), and am likely going to counter it with some weight in the tail. Thoughts?My io-375 has 9:1 compressions, superior cold air induction, e-mags, and the hartzell trailblazer 83” prop. Its the only engine that I’ve had on this plane. The plane weighs 1274 with belly pod and slats on 35s. Before the slats and pod it was 1225 (with 8qts of oil in the sump). It has an amazing amount of acceleration, everyone that rides comments on it. Before slats and pod at 75% power and 3500ft it would do 120-125 indicated. 65% would get you about 105-110 and 55% about 95-100. Thats on 35s. Fuel consumption at 75% was over 12gph but at 55-65% and lean of peak im getting 6.5-7.5 gph.
Hi Johnny, I've been thinking of following this path for my oil cooler - do you have a picture of how the hood scoop connects to you SCAT tubes to feed air to your oil coolers please? I was wondering if a large naca scoop underneath the scoop would do the job....No issues with oil temps, as we have dual coolers fed by a ram air scoop on top of the cowling. Here’s a side shot of the full cowling
I take it you run out of elevator during landing. Where is your trim set? I would not add weight unless you have run out of trim, gap seal in the tail will help also.prox 7 lbs in the aluminum fork at the bottom of the rudder.... or, potentially up to 6 lbs of antifreeze in a baby bushwheel without losing cushion? I took off a 320 and put on a IO-375 and a CS prop and gained enough that I run out of elevator without power. Few perfectly before adding the extra weight (even loaded with a passenger), and am likely going to counter it with some weight in the tail. Thoughts?
I am south for a few months so can't take pics. Suggest you call Legend Aircraft in Sulphur Springs TX to discuss. They may be able to hook you up with a build diagram or even sell you the scoop + outlets. It's a pretty simple design.Hi Johnny, I've been thinking of following this path for my oil cooler - do you have a picture of how the hood scoop connects to you SCAT tubes to feed air to your oil coolers please? I was wondering if a large naca scoop underneath the scoop would do the job....
