View attachment 20502Everyday hamburger hamburger hamburger,does anybody know why you American like hamburger so much?But I love it,very different from Chinese food,delicious.
Manual flaps,good suggestion,the electrical motor drivers flap slowly,I would abandon it.Manual flaps. Straight forward install and fast to put on and take off.
Power. Get as much out of the O360 as possible, this is where I spend the money
Unless you have a serious need for 35s Id' go with smaller, even 850s ,I fly the lower 48 and I haven't really ever needed bigger tires, they are heavy and slow you down(my opinion)
3x3 gear, adds a safety margin to the airplane, 180hp on a 3 in gear with big tank fuel can go over in a new York second
One major advantage of building an X18 is the amount of engineering available not to mention every part imaginable is available for sale. If you are like me you want to fly as soon as possible. Before making major engineering modifications, evaluate it for the project completion impact. I have a saying about airplanes. Everything is related to everything. Meaning, you make a change to a part and the change will ultimately impact something down the line that wasn't on the radar just yet. Stay as true to the original design for the sake of getting it completed.
Regarding tires,they laying on floor of my basement in China.I havnt choice, the price is doube than AK's when they arrive my address.The policy of airfield management is very strict,they said the heaven form your hair belongs to govement:roll:.Bullshit,I believe,if you jump in air for 1 second the goverment wouldn't arrest you,believe me.Regarding Bushweeels and 35's vs. 8:50's...If you need to make an unscheduled landing in China there is a LOT of rough terrain - in fact almost all of it, except the central plains where there are some open areas,but small fields and a lot of obstructions. You might consider the loss of cruise speed against the potential loss of your plane. Considering the near complete lack of AvGas and the unspecified quality of auto fuel in China, the chances of an unscheduled landing are way higher than say, in the USA or UK. I'm told that several Cirruses have gone down while flying on auto fuel in China. Although an injected engine with pressurized fuel flow is trickier than gravity feed, I urge you to consider the big tires. Chances are you'll need them, and from what I've seen on 12 trips throughout all of China in the last 16 months, there aren't a lot of friendly places to land - besides military airfields, and we both know you aren't going there unless it's life or death - or a visit in prison. What's more, given the usual near-zero visibility conditions in haze and pollution across the majority of the country, you may be forced to land at short notice. I suppose if your in Xinjiang province near Urumqi or Karamay, you're OK, but even there the sand is pretty uneven. By the way - will you come and visit us at the World Air Carnival in Zhengzhou, 25-27 September? We will fly aerial Skyboard® banners on our Husky. See you there!
With the Riblett 66" wing, you will need to either modify the bird cage so it fairs nicely across to the wing root, or will need to make step-down fairing which will have look like Zenith or Gullwing. Just a heads up.
My project start from sketch,I made every parts including ribs,a wing kit could save time,but couldn't save$$$.Which wing kit are you going with, D&E? It could be made to work like stock Cub, although the upper balance cable might have different position on the rib than normal to make sure it passes through cockpit in right place. The D&E Riblett wing originally was configured to work like the PA-12 with cables all routed on the rear spar. I could have done the Riblett on mine but decided against to avoid excessive mods that will add considerable time to your project.
I will be loaded down with aerial billboards and kit, but if your parts are small enough I'd be glad to help. Where are you? My associate Lei, will be traveling to Shenzhen and Wuhan enroute. I'll be in Hong Kong enroute. One of our Huskies is on a sea cruise now and should be in Zhengzhou by 17th Sept for banner flying at the Show.
Also, my friend Walt McFadden may come to be interviewed on CCTV. He was a P-51 fighter pilot, waiting to fly to Japan when they dropped the bomb. A truly amazing man.
Here are some links to the World Air Carnival, celebrating the 70th anniversary of victory over Fascism.
http://wx.zhongledp.tv/zhongchou/3846044.html?from=groupmessage&isappinstalled=0
http://tv.cntv.cn/video/C10598/2d8203ad088048a383762857d5932e36
P.S. My associate in BJ imports AvGas, but you need to buy an ISO container. That'll fuel your Cub for years to come.
I understand what 3x3 gear is,that's extend 3''leg length and move the axle 3'' forward.Thank you very much.Manual flaps. Straight forward install and fast to put on and take off.
Thank you so much,actually I am waiting for the answer.I am fabricating a 6X3 HD landing gear,I never heard somebody had do this.Front tube 1 3/8 thickness .08inch,I am not sure this is a right way.I had a 6'' extended gear. About 73'' inside disk brake, and about 86.5'' outside axle to axle.
I would keep the angle at 45 degrees.
You can reach her on WeChat at Sunny-US-HK. She is not fuel supplier. Talk Chinese to here. She's in Arizona.WhiskeyMike,could you give me your associate Li's number?Maybe I will buy Avgas form him or she.I have your mobile number in China,do you still use it?I sent a message to you in 9 May 2014,but no reply.
I need to build a brand new baby, and I need riblett66 "wings, to get a very good performance. But riblett66 "wing of the control and the body is connected with the pa18 completely different, I do not know how to connect the body? Which have riblett66 "wings of the drawings? I also need to connect with the fuselage with the control method, the pulley position? Who can help me to solve this problem, thank you!
