marcusofcotton
Cotton, MN
As far as welding rod and technique, I'd use the same as you are comfortable with on the fuselage tubing. Unfortunately I cannot speak knowledgeably on the further welding specifics, sorry.
Both of these parts are not airworthy. They both have sharp corners and notches where the bend is made. This will start a crack over time and will fail. The first part holds the wing on the plane.
as I turn around and look at the Airframes fuselage, and it looks to be the same bend radiuses.... and those are each only HALF of a 2 piece welded item, the notches get disappeared in the edge welding process....
Mike , I'll agree on the lift strut fitting. I don't know what those other fittings are. Those cuts right at the reverse bends look bad. Are they welded? Depending on their use that could be a highly stressed area.
Yes,I got a Interview Invitation Notice that form Canada at 29th this month,but I will go to Yakima frist,for my tailwheel endrosement.Congratulation to you will got a daughter-in-law,but be careful,chinese daughter even in law would empty your wallet.Lol,a joke.I have to Canada eventually.The earlier post concerning cost, remember it's relatively expensive to live in the U.S.A., Most of the parts come from FAA approved shops, I think even raw materials are more expensive here and don't forget our lawyers. Only the government section of the phone book has more entry's than the legal section so a lot of liability risk here. I'm sure the owners live a little better than the workers but unless the aircraft part is a side business I don't think we have to many really rich shops over here. Were lucky we have the decent businesses supporting aviation that we do. Very specialized and a lot of one off parts. All that said it's still expensive for the hobbyist. The aviation businesses here are of course low hanging fruit if China wanted to go after them but I can't see how it would be worthwhile except for maybe the amateur built market and we are pretty fickle.
Your parts look real good! I have made some of those from scratch and I know how hard they are to figure out. Are you still coming here eventually or do you think private flying will become more encouraged there? My sons girlfriend returns to Beijing on Saturday.
Really?but I dont think so,they are made of .118inch(3mm) thick 4130N steel plate,thicker than normal PA18 buleprint shows,the notches came from my design for aim of bend easy and reduce stress,they will be weld togther when install.Pls visit www.super-12.com,the parts they make same with mine.Both of these parts are not airworthy. They both have sharp corners and notches where the bend is made. This will start a crack over time and will fail. The first part holds the wing on the plane.
And I will use electric heat string heat treat all the tube join of my fuselage.And the string can work with 110V 60Hz,only $10USD per feet.View attachment 18506
I think heat treat the welding section will not change the tenacity of the material,but can eliminate welding stress.what do you think?probably unnecessary step..... you just end up loosing the "nice shape/bow" of the longerons.....
