8.50 x 6 Tires for the PA18...Brand preference?
So I stand corrected. Just checked the tire rack and here's where the 850x6's are made:
Michelin: Thailand
Goodyear: Thailand
STA (Specialty Tires of America AKA Desser) Air Trac: USA
Other tire sizes like 800x6 and 700x6 have the Goodyears and Michelins made in the USA and the Desser tailwheel tires, and Airhawk lines are made overseas. To be perfectly clear, the majority of the tires I've dealt with under warranty were the Airhawk line and not the Air Trac line. Different quality levels from the same manufacturer apparently.
Heh. Before you posted this you made me go out and look. Yup. My Air Tracs say "Made in USA"
I've heard comments on this site (mostly from one person) that airtrac 850's
1) are smaller than GY 850's,
and
2) don't wear as well as GY's.
My C180 had a set of Desser-recapped 850 GY's on it when I bought it (they wore like iron BTW).
I replaced them with a set of Airtrac 850's,
and didn't notice any significant difference in size.
3-1/2 years later, I have 874 landings on those tires, mostly on paved runways,
and they still have a lot of life left in them.
So they seem pretty durable to me.
FWIW that same person always sez the 26" GY's are hardly any bigger than 850's,
here's a pic of a 26" GY next to a mounted 850 GY recap.
And a pic of a 26" GY compared to an 850 airtrac.
and
Well, that "someone" would be me, I'd guess.
1) I stand by my statement that Goodyear (and Michelin, BTW) are larger in diameter than the Airtrac 8.50s. Perhaps the Airtracs have increased in size, but those "smooth 8.50s" they put out look tiny by comparison. I've actually put MOUNTED Airtracs next to MOUNTED Goodyears, and there was a good inch difference in diameter. BTW, those came off the same airplane, a 185, that had some handling issues..... Is the difference in size huge? No. But, as Steve Pierce alluded to in this thread, the Airtracs have a much more rounded profile, where the Goodyears have a much more square profile. Put a load on those different tires at operating pressures and measure them.....that's where it actually counts, NOT uninflated, laying on the floor.
2) I've run quite a few tires over the years on various airplanes. It has now been quite a few years since I ran Desser 8.50s because, as others have noted, I just got a LOT more wear out of Goodyear tires. That's my experience, your experience may differ. So be it.
As to your photos, I think you need to consider comparing apples to apples.....for example: "here's a pic of a 26" GY next to a mounted 850 GY recap." A SMOOTH GY recap may or may not represent an actual Goodyear production 8.50. And, the 26 inch Goodyear is not inflated, which generally tends to splay the tire out some. Comparing a mounted and inflated tire to an uninflated tire can be misleading.
Then you compare a 26 inch Goodyear to a Desser 8.50. As I noted, the Desser 8.50s have a rounded profile, and aren't that large in diameter anyway.
When discussing the Goodyear 26 inch Blimp tires, the argument that many suggest is that they are actually 26 inch diameter tires. They are NOT 26 inch diameter tires when inflated to operating pressure and mounted on an airplane. Compare a Goodyear Blimp tire to an actual 26 inch tire, such as an Alaskan Bushwheel 26 inch, and you'll see how much smaller they actually are. They're much closer in diameter to an inflated Goodyear 8.50 than they are to an actual 26 inch tire. The blimp tires are WIDER than an 8.50 tire, and that's important when it comes to floatation. Pick your medicine. The single biggest issue with the Blimp tires is that there are very few approvals for them on production aircraft.....and they are heavy.
Finally, I have had two faulty Desser tubes recently, and will never purchase their tubes again. I know two others who've had similar experience. I hope Desser figures that out and fixes it, but till then, no thanks.
In the spirit of full disclosure, I am now running Desser Air Trac 8.50 x 10 tires on my airplane, mostly because the Goodyear 8.50 x 10 tires have more plys and are HEAVY. I'm actually hoping these tires will wear a bit, frankly. Time will tell, but so far, so good. Goodyear natural rubber tubes, BTW.
A fellow I know installed a set of the Desser smooth 8.50 x 10 tires last year, and they are cracking badly already. Bad batch? I dunno, my treaded 8.50 x 10s seem to be holding up after a year and a half.
I have just NEVER had a bad Goodyear aircraft tire or tube, and I had a set on my 170B for a loooong time, always parked outdoors. I have had bad Desser tires and bad Desser tubes.
That's my experience. As to sizes, it's all relative, so pick the flavor that winds your watch. But compare apples to apples.
Good Year and Michelin both make a good product. I am probably going to put some GY 8.50’s on my Super Cub project initially.
....Then you compare a 26 inch Goodyear to a Desser 8.50. As I noted, the Desser 8.50s have a rounded profile, and aren't that large in diameter anyway.....
Mike, Desser makes Aero Classics (some of which are smoothies), STA (Specialty Tires of America) makes Airtracs.
Two different brands.
My tires die from weather checking before the tread wears out. Aero Classic is the worst offender. Bushwheels are right up there. AirTracs and AirHawks do okay. Hell, I have two sets of badly checked AitTracs in the hangar, but both are at least 25 years old. I need new 850s for the Cessna skis. I think I’ll buy Michelins. They appear to hold up well.
I'll be getting 8.50x6 tires soon for my build and want a smooth tire. What products have smooth tread besides the Desser 850x6 4 ply tundra tire? I wonder if a retread is the only way to go smooth with a Michelin or GY? Who make the best inner tube?
A while back, there was a spate of synthetic tubes splitting. I had one split wide open upon first inflation. Others got farther along before they turned loose. These were the “Leak Guard” tubes. I was advised to only buy natural rubber tubes. Last I’ve bought were Goodyears.
Natural rubber tubes leak a little over time. Not a bad idea to check tire pressures occasionally anyway.
Hopefully, whatever the issue was with those “Leak Guard” tubes has been fixed. This was last year.
LeakGuard tubes used to be the way to go,
but lately I've been hearing bad reports on them.
Lately a local shop has had a number of them fail prematurely,
either by splitting or due to pinholes / porosity issues.
