The part of the front brake pedal that your shoe contacts should be parallel to the part that connects to the rear brake. Brian at Steve's Aircraft realigned mine, with brute force, in place. I was definitely impressed! Those guys know their stuff. It all works fine now.
.... Keeping slight even pressure on both pedals will remove the slack so your inputs will do something instead of tightening the rudder cables. Make one foot slightly over power the other and you won't over control when your first input don't work Glenn
I will have to go against the advice of some here. You should learn how and when to use brakes early in your training......DENNY
It’s a cub, unless you are landing on a 400’ strip why do you need brakes? Just keep it straight with the rudder
Toe brakes are evil, and are the cause of a huge number of skywagon and carbon cub landing accidents.
I agree. Brakes are a control input and as such should be used when necessary.
I teach this all the time, and it really helps.
As for brakes, people who fly skywagons are a bigger proponent of using brakes because they frequently run out of rudder. I never use the brakes on landing (except to stop - what they were made for) in the cub, but do occasionally have to tap the right one on landing in the 180.
Why do you say that?.
Re Post #84: I like the Cub rudder pedals to almost touch the firewall under full pressure. That allows my ancient feet (often inside thick winter boots) to work the heel brakes some, but rarely when slowing and rather more when slowly turning if the tailwheel or rudder are lazy to respond. Like in a stiff crosswind while taxiing.
I don't recall in primary training or later any instructor demonstrating brake action or effectiveness. Seems like it was self taught through hard knocks. Then once skis were installed and flown on icy surfaces the use of brakes went disappeared and other things were needed to steer or stop.
Too many experiences checking people out in various planes (including carbon cubs) where they inadvertently got on the brakes. It can be learned, but lots of primary nosewheel pilots land with their feet already on the brakes. It does not transfer well to tailwheel. I prefer to introduce people to tailwheel with heel brakes. keeps everybody out of trouble.
I've been told that 50% of Huskies have been on there nose as a direct result of toe brakes. Might be a bit exaggerated but they are notorious for going over. In an effort to help the situation foot/heel wells are an added to the floor board as a safety feature on Huskies.
Bingo, all new TW inductees need to learn on skis first
Interpretation 2. Of all the Huskies that have been on their nose 50% of these incident were the result of Huskies having toe brakes
Sooooooo This year I had the opportunity to let a young 5,000 hr ATP jet pilot get his taildragger endorsement in my cub. He is family married to my wife's nieces cousin. Ya some distance but nice kid and a someones got to get them trained. So we started on skis like the wise pilots say, I was able to show him how running off the glare ice runway was not bad as long as you miss the lights. He did it a week later but in he's defense it was a tailwheel issue. In the spring wheels came out and he had a week free I called in a CFI buddy for proper training and sign off. After his sign off he was out of state for a while so we went out for refresher flight and did ground loop practice at Big Lake strip. Yep, how many of you have ever practiced or trained on how and when to do an intentional ground loop? At 15 mph in a cub it is not a big deal and a whole lot cheaper than getting on your nose or all the way over. My IA pounded it into me that it was a lot easier to fix a tail or wingtip then a prop/engine teardown/both wings/jig the top deck!! I would much rather he get a wingtip then flip my cub so proper braking was talked about from day one. So when I say pilots should train to use brakes that is what I mean. What if everyone was trained on how to do an intentional ground loop?? How many planes could we save from going over?? I know of a few just at my home airport in the past few years from pilots not properly trained with brakes. Just like Spin/Stall training, hope to never get in an unintentional spin but now the reflex has been built in when it happens!
Now in defense of all CFI's, pilots are about the cheapest thing you can find on the planet earth. They will pay 2 grand for a watch that has a little timer hand but bitch and moan like you want the first born if they have to pay a CFI for a few more hours of good training and what FAA reg talks about intentional ground loop training?? If it is a new student pilot you will just overload them with info so ya you can only teach so much.
Now if it is a GOOD pilot with 300 or more hours then it should be mostly just ground training, tail up, tail down, one wheel, than the other wheel, proper trim, proper rpm, braking, cross wind, ground loop, run off and on the runway a few times just to show them it really is fine as long as you don't hit things with the props. (I got 3 lights with wheels over the years). All that will suck for the CFI because they will all try to kill ya the entire time!! In the end show them a single 3 point landing because even nose wheel pilots know the best way to land a plane is a wheel landing because the is all they do!!
