• Folks, some quick guidelines for using the classified section of the forums:
    1. Only supporting members can post ads.
    2. Ads will be deleted for expired members.
    3. Ads will be deleted if not updated in 45 days
    4. Please delete your ad when you have sold your item!
    5. Please choose the proper PREFIX - FS or WTB - when posting.
    WHEN THE ORIGINAL POSTER MAKES A POST WITH THE WORD "SOLD" WITH ASTERISKS ON EITHER SIDE (LIKE THIS "*SOLD*" ) IN IT ANYWHERE, THE CLASSIFIED AD WILL BE REMOVED WITHIN 24 HOURS OR SO
1957 Champion 7FC
Tx
1957 Champion 7FC totally restored in factory colors. C-90-12. Light weight B&C starter, alternator and firewall mounted battery. 4hrs sense total restoration by renowned champ restorer. New wood, control cables, all hardware, interior, headliner, instrument panel, fuel valve, gascolator, windows, sheetmetal, baffles, and cowling. Becker com and transponder, panel mounted Garmin portable. Toe brakes and adjustable front seat New crank, cam and lifters at time of rebuild. Recently removed engine and cylinders to inspect for corrosion. Fun flying rare airplane that needs nothing. The owner/ Restorer built this one to keep but got sick and hardly put any time on it and recently passed away. The engine was overhauled less the cylinders, he had them IRAN'd. Not sure why you would go through the trouble of replacing the cam, lifters tappets crank bearings and through bolts and not do the cyl, but the engine has 525 sense overhaul, and a couple hours sense the cam was replaced. Airframe has 2638TT with complete logs. I have a google drive with more pics. $55,000
