So I recently installed Micro VGs on my Cub and noticed a great improvement. Thoroughly pleased.
Would I expect the same if I installed them on my 185
F model on amphibs, long range tanks. No other STOL mods. Stock wing tips
or is it a waste and should spend the $$$ and go with a full STOL kit with VGs
My experience with adding VGs on three Cessna wings was that they sort of mellow out the stall, but not enough that I’d do it again. One of those planes had an early stock wing, one had a Bush leading edge kit, the last has a Sportsman cuff.
the VGs “mellowed” the stall a bit on all three.
But, hands down, THE BEST aerodynamic thing you can do for a Cessna wing is add the Sportsman kit. I put a couple thousand hours on a 185 with a RSTOL kit. Management wanted to try a Sportsman kit on one of our 185s. Mine got volunteered. I loved that plane with the RSTOL. Added the Sportsman, and it allowed me to SAFELY use that RSTOL kit.
It was amazing. I put a Micro VG kit on my 180 hp 170 and was pretty disappointed. It mellowed the stall a bit, on a plane that had a mellow stall to start.
VGs work well on a Cub wing, but in my experience, they don’t make nearly as much difference on a Cessna wing.
The Sportsman is the bomb on a Cessna wing. My current ride has that kit, and I love it.
Finally, I fueled that 185 myself almost all the time. It spent half the year on floats, so hip boots. I’ve come really close to cutting myself REALLY bad fueling with VGs.
VGs work on Cubs. I’d never put them on another Cessna.
