Tom3holer
MEMBER
Cape Cod
I have had my 185 for just under 2 years now and have learned a ton form the many questions I've posted here and want to say thanks again to all of you.
My IA and I rebuilt the stab last year as it has a bit of slop in it. The trim issue was in play before we rebuilt it. We replaced a bunch of stuff and aligned the stab jack screw bushings. It has no wiggle and trims quite smoothly until the speed get up to around 140mph and higher. In a descent I cannot trim into the yellow as it gets very hard and will start to trim nose up on its own slightly. Trim cable tension was checked and it was fine. Basically aerodynamically it does not want to trim nose down as speed increases. I realize this is a common issue with the 180/185. Had a 58 180 many years ago and do not recall the trim issue to the extent I am having now. I know the 185 is nose heave although I have the battery in the back and carry a 20-25lb tool bag in the back of the extended baggage compartment. It would seem that additional weight in the rear would make the matter worse although there is probably more aerodynamic forces at play than I realize. Have read in posts in the past where some owners report no issues with higher speed nose down trim.
Any thoughts or suggestions would be greatly appreciated.
Tom
Tom
