Bob Breeden
Alaska
I tried to figure out how to post this question on the Skywagon site to no avail, so here goes:
The '53 180 I am restoring (with my AI) has play in the horizontal stabilizer. After removing the fairings, it is obvious that the rear 2 lower hinge plates are moving (rocking) on the bottom surface of the horizontal stab when the tip of the stab is moved fore and aft by hand. There is also too much motion when the tips ar pushed up or down, though that has less travel.
There is only one HOLE drilled for 1 BOLT on each hinge plate to stab connection, though the Service Manual shows 4 holes/bolts for each hinge. In contrast, the front pair of trim jackscrews are relatively tight -very modest amount of movement up there.
Any ideas or proven methods to keep the 180 fully trimmable tail healthy?
Yes, the airplane is flat grounded until this is sorted out.
Bob Breeden
www.AlaskaAirpark.com
Bob Breeden
