I have two Cessna 180s. A 1960 and a 1969. We bought the 1960 about nine months ago and it had been stored for 12 years in a hanger with the tanks full of 100 Ll. I was able to put a replacement magneto on it and fly it home the day I bought it. It’s very clean and we really love it. I hate to admit it, but it flies better than my pponk 180 In terms of performance.
We now have about 50 hours onit, and are having a lingering problem that we can’t solve. Occasionally, the engine loses power upon acceleration for takeoff. The first few times this happened the problem was very severe. To the point where we did not takeoff and left the airplane at the outstation while we troubleshot the problem.
This is a stock airframe with 65 gallon bladders. Along the way we have determined that the bladders are in very good condition and clean. They were put in in 1996 and 2006. The finger strainers are clear. I had the filler assemblies off and did find that the bladders were not clipped to all points on the top of the wing interiors and we corrected that.
The gascolator is clean. The carburetor intake filter is clean. The fuel hose between the gascolator and the carburetor is new and is clear. We get over 30 gallons an hour of static flow out of the flex hose measured into a canister.
Normal takeoff on this engine is around 22 gallons per hour and under normal circumstances that’s what we get.
We are not having the severe problem that we once did and it does not happen every time. But tonight on takeoff, there was a momentary lapse, and when I glanced down, I saw only 14 gallons per hour on the fuel flow, but it quickly picked back up to 22. I am running out of ideas.
When this originally occurred as a problem, we found that the static flow was way low. We solved it by blowing backwards through the system to the tanks. I felt like we probably dislodged some restriction, and I figured it was in the tanks, blocking the finger strainers. That got the static flow back up to normal. At the time we drained all the tanks by pumping them out through the filler ports, and filtered all the fuel so we knew we had clean going back in. And this was after flying about 20 hours without issues. With the recent issues, I did open up the tanks and found the bladders to be extremely clean, so that’s not the issue.
I have never had one of these fuel valves apart. Is there anything inside there that could be moving and creating a blockage? That is the only thing between the tanks themselves and the carburetor that we have not had apart.
To summarize, this only occurs on initial acceleration on takeoff. Once the engine gets up to speed, it stays up to speed. Any ideas appreciated!
