SimonK
Nome
Well, I was hoping I wouldn't have to write in about my engine, but I'm getting to the point where I'm stuck on how to proceed.
My PA-14 has an 0-320-A2B (150 horse) with 500 smoh. I have a McCauley 80-44 prop on there right now, and the best I can do at static is 2250. I understand that I need to be at least running 2350 to be within limits (although that is just what a mechanic friend found while researching the problem). My takeoff roll is particularly unimpressive, which leads me to believe that it is not a tach error.
I searched on the website to see if I could get past advice on what to look for, which I did. On Saturday we checked the following items:
compression (all mid-70's)
spark plugs (removed, inspected, cleaned)
mag timing (dead on)
intake leaks (found none)
mag drop was minimal
throttle cable was in adjustment
carb heat was in adjustment
drained the carb
removed gascolator (fine shape)
inspected air filter (fine shape)
exhaust (looked up with a flashlight, cage was fine- did NOT remove, but did bang around on it to listen for internal movement- none)
I also tried leaning the mixture while at full throttle (static) with no appreciable increase in RPM.
Basically, we didn't find anything wrong. A couple of questions:
Does the 2250 (which may be a bit generous) with the 80-44 prop sound low (everyone I've talked to thinks so)?
Anything else I should be checking (besides serious internal parts, which is out of my league and I imagine must get expensive really quickly)?
I've read about various options for increasing static RPM such as the K&N air filter or the Leading Edge Exhaust System on, but I am worried that doing so would simply hide whatever problem exists. Does that seem right?
I appreciate any help I can get. I also realize I may be omitting necessary information, and if so would be glad to fill in with more details if able.
Thanks much!
Simon
drained the carb
Thanks much!
Simon
