BENEFACTOR
They use a 64 micron now, 10 was to fine.
..Decided to add the Airflow Performance filter to the fuel system.
View attachment 50735 Here it is linked to the red cube before going to the gascolator.
Dan
Why use the fuel filter? Gascolator screen catches everything and there is a finger screen in the carb as well that I can never remember finding anything in.
I agree with Steve. Consider, what happens if you clog that filter from the drum up north? How will you know there is a contaminate in there until the engine stops? There is no drain to clear it out. Any contaminate will just build until the fuel stops flowing and you will not have a clue there is an issue until the engine stops making noise. The gascolator is designed to collect the contaminates at the bottom of a bowl prior to the fuel going through the screen. It has a quick drain to dump those contaminates from the bowl. With this fine mesh screen installed where it is located no contaminates will ever get to the gascolator except perhaps water. It will clog with big particles. As Steve mentioned, the carburetor has a finer mesh screen which will catch any small particle which make it through the gascolator. I, like Steve have never found contaminates in the carb screen.Steve,
The Airflow performance is a 125 micron pleated stainless filter with a capacity of 180 GPH. In 15 years of manufacture of this filter there has not been to date a restriction of fuel due to clogging. That does not mean that it can't happen! I know that might be an overkill but when you fuel out of 45 Gallons drum up north...You just don't know what's in it.
Dan,
That's some mighty fine looking work. If you put windshield defrosters through the the dash, you might consider separate controls or some sort of diffuser. I've seen distorted windshields from too much heat. Also, are you going to get enough air moving through the system to make everything work?
Did you get your new gascolator? Whatcha think?
Jim
I probably don't have a problem with foggy windows thanks to my tail/rudder post junction being uncovered. A trick I learned here, to make it easier to keep an eye on that heavily stressed area. Numerous other leaky areas also, ensure plenty of airflow, winter or summer, for better or for worse, but maybe a fog free front window is a unexpected benefit. My vehicles are tight, thus the need for a defroster in them.
A 160 HP is over well over 200 degrees at the scat tube in the cabin, measured with one of them fancy temp guns. This is an Attlee hot rod exhaust with heat robber.
The fan is interesting but probably unnecessary. It'll be interesting to see if it improves the airflow. In a perfect world I'd like my Cub heat to have a cold air mixer that increased volume and reduced the temperature like a Cessna heater does. It wouldn't be hard to do in my plane but in truth I never use much heat. If I can take some of the chill off my face, ears, and fingers I'm good. The rest of me is dressed for the OAT.
I can assure you it really improves the airflow. I tested it with a sheet of paper about 6 inches in front of the cabin heat box and it sucked it in all the way to the fan...Pretty powerfull. Now, by opening the lower flapping valve and by controlling the amount of hot air coming from the heat box I can mix the right temp going to the Windshield / Cockpit. That'll be interesting to see if it really works as advertised once the aircraft is flying in these different weather conditions.
Dan,
I am very impressed with your fabrication skills, but it pains me to watch that plane getting heavier by the minute :???:,
You had mentioned emphasis on creature comforts earlier, but light nimble Cubs are such a pleasure to fly.
I should probably mind my own business, but weight adds up quick and should factor into every decision during build.
just my 2c
keep up the good work!
doug
