I've built a set of slatted (not yet) 17' wings, with the flap-aileron tunnel straight to the tip:
I want to built a wing tip fence to finish the wing tip. Something like this wing:
But I don't like the idea having something that ''hangs'' under the wing.
Would it be as efficient if the fence was only on top of the wing?? To force the airflow to stay on top of wing??
Any more design of fences??
I did my try with my paintbrush skills...
From small to big fence only on top.
This thread is about all I was able to find on flat plate tips using the search function. Not a Cub but my RANS S-7S. What prompted this was my aluminum tube tip bow, used to be covered with kit supplied plastic tips, that did nothing but add a bit of weight, purely cosmetic, and I took mine off 1500 hours ago. But just the other day, walking by the plane, I noticed a couple 3/16" holes in the sides of the tip bow, and remembered that they were there for the assembly process: my wing jig spinner thing attached there, via nut plates. So, I spent about 20 minutes and bolted on some 7/16" OSB, taking a purely WAG on what size to make it, and went flying.
It stalled at the same number, but I only tested it with no flaps, but it seemed to reach a higher AOA, though at the same number. Then I shot a half dozen landings, all on slopes and holding it off as long as possible with lots of power, the last 2' above the snow, safe enough. These tips SEEMED to let me land even slower, hold it off longer, then I already do, which is really slow. Then I tried a high speed cruise, high speed for me anyway, 83 ind. at 7K, and if anything, it seemed to go maybe 1 to 1.5 mph faster WITH the OSB tips, this was a major surprise. It for sure was not slower anyway. For test purposes, the neat thing is I can jump out and take these off in a minute per side and throw them in the baggage. Out of pocket cost was zero, and I already had the means to secure them already there, seemed like a fun thing to try.
My next move, if I do anything, is to have a local composites guy make some carbon fiber ones, but if I do that I want to guesstimate the shape a bit better. These stick down about 1.5" below the bottom surface, not shown in the picture, I did that, just because, I guess. I for sure didn't want to block my side view so didn't consider going further. The top is also something I just intuited, WAG'd at. And the last rib is inboard a ways, like a Cub the tip bow is tapered down from the last full rib. I would also make them sexy looking, not like the squared off test ones, goes without saying! Any advice or info on this flat end plate fence concept, or whatever they are called, would be appreciated.
