Results 1 to 16 of 16
Thread: Wip 3000/C-185 tail ballast
    Aug 2022
    Sherman, CT
    79
    Just ran across this C-185 on Wip 3000 amphibs, couldn't help but notice the tail ballast. Panel is placarded something to the effect of "tail ballast must be installed". I am told that the ballast is required per the STC. I have several friends operating the same aircraft wClick image for larger version.
ID:	66934ithout the huge ballast mounted on the stinger.
    12,947
    Quote Originally Posted by rv6ator View Post
    Is there a question in there?
    8,346
    I had to get a field approval for something a lot like that for a Helio. Pulled it out when they put the aircraft on wheels, and now use it for a giant bucking bar.
    That one was a piglet on floats.
    Aug 2022
    Sherman, CT
    79
    OK then, the question is "why do most C-185's on Wip 3000's NOT have this ballast installed"?
    8,722
    Because they add weight as cargo? CG doesn’t know the difference.
    Likes DENNY liked this post
    12,947
    If the ballast is a required component of the Wipline STC, it may be that, when the plane goes from wheels back to floats some spring, the mechanic “forgets” to re-install that ballast, which would have been removed when the plane went to wheels. Oops!
    I’ve seen stuff like that stuck on a shelf in a hangar, and nobody knows what it is…….
    Now, again, IF the ballast is required by the STC, the airplane on those floats without the ballast would not be in an “airworthy condition”. If in an accident, especially a landing accident, that could turn ugly pretty fast, assuming the FAA Inspectors who investigated were knowledgeable enough to recognize the absence of the ballast. Insurance company might not be happy. Both the mechanic who installed the floats and the pilot would be culpable.
    If the STC doesn’t specifically require the ballast, then it’s strictly up to the pilot to ensure that the plane is loaded within its CG envelope for every flight. An empty airplane does not necessarily need to be within its legal CG range to be “airworthy”.
    I flew a 206 that went to floats in summer. On floats that airplane was limited to max 30 flaps, and the float STC specified that. The mechanics didn’t want to re-adjust the flap limits spring and fall, so I talked them into installing a small bar on the flap selector switch that limited flaps to 30 for floats. After the first winter on wheels, the mechanics installed the floats and forgot to re-install the bar. I never brought it up. I love 40 flaps, used judiciously, of course.
    Likes DENNY, Pete Schoeninger liked this post
    Bill.Brine's Avatar
    Aug 2012
    Massachusetts
    491
    This was on an early 180 used for racing at Reno.
    Lots of other interesting mods on the plane.
    Likes jrussl liked this post
    Waldo M's Avatar
    Jan 2018
    Finger Lakes area, western NY.
    218
    If the folks operating those airplanes on Wipaire 3000As fly with 2 people in the front seats and no people, moose meat, or about 50 pounds of ballast in the aft baggage area, they will be operating the airplane with the C.G. beyond the forward limit without the tailwheel strut ballast.
    Likes Farmboy, Bill Rusk liked this post
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY & Middlebury, VT
    3,149
    The required placard is actually to the effect of “it is possible to exceed the forward CG limit if tail ballast is not installed….”
    Which is the same as Mike stated, it’s the pilot’s responsibility to fly within CG.
    But, it is Wip’s approval that that requires the placard.
    If you’re not hauling a load, I highly recommend adding tail weight to move the CG into the middle. And I’m not even a 185 driver.
    8,722
    How does the empty CG differ from 2870s and 2960s? I flew both on my Wagon without ballast. Heavy, light, never any issues. No flap restrictions, either, unlike my previous electric flap airplane. That 40° flap restriction was a placard only and was quickly disregarded, as instructed by my DPE during my float check ride. I figured the restriction applied to full flaps-full power go-arounds. Floats made it harder to push the nose down.
    13,237
    2870s and 2960s are straight floats. Most amphibs with the heavy nose gear way up front are nose heavy. That 185 in post #1 is likely one of the few which is within limits under most all conditions. It is difficult to meet or exceed the aft limit on a 185 amphib.
    NX1PA
    Dec 2016
    Canyon, tx
    1,144
    [QUOTE=Bill.Brine;851655]Click image for larger version.
    What other mods did you catch on Warrens wagon other than the lead and Acmes?
    Bill.Brine's Avatar
    Aug 2012
    Massachusetts
    491
    [QUOTE=KevinJ;851660]
    Quote Originally Posted by Bill.Brine View Post
    Did I say it was Warren’s plane?
    The year of the gear legs do not match the direct read fuel gauge..(not sure the legs matched the gauge- newer legs with an old gauge).
    Also had an 83” MT.
    The plane was old, well loved build.
    Likes KevinJ liked this post
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    798
    The installation drawing allows the ballast weight to be installed as “an alternate for aircraft loading to obtain weight and balance limits.” In other words, you can load up your airplane with gear and beer, or you can install the ballast weight, or some combination of the above. You can trim the ballast weight to get to the proper weight for your aircraft CG.
    3,324
    Quote Originally Posted by Amy View Post
    YEP, just plain common sense right in the the instructions!! Much better to use the cargo to adjust CG than adding useless weight.
    13,237
    It takes a lot less ballast weight than it does cargo weight to place the CG where you want it. On the other hand if you never fly empty or with a small load use the cargo.
    NX1PA
    Likes DENNY, Farmboy liked this post
  1. Fli-Lite 3000 Ski
    By Poor Joe in forum Modifications
    Last Post: 03-12-2023, 12:03 PM
  2. Fli Lite 3000's
    By superchamp in forum Cafe Supercub
    Last Post: 11-10-2006, 11:57 PM
  3. Scott 3000 tail wheel
    By Thom in forum Super Cub Sick Bay
    Last Post: 08-05-2002, 12:40 PM
