Results 1 to 8 of 8
Thread: Leaking Carburetor Cause Discovered.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,262
    As a follow up to my previous, and poorly explained, post about my leaking carb on the 12.
    It turned out the float decided to be a submarine. See attached photo. So it filled full of fuel and sank.
    Thus it was flooding like crazy. So a new float is on order.
    I have never seen a semi-clear white float before. It has a Eagle or Hawk face logo.
    As I am sure you know. there was a 2009 service bulletin regarding improper floats in Marvel Carbs.
    https://msacarbs.com/pdf/SB-2_B_RPLm...ats_062209.pdf
    We also discovered that the primer lines were spraying fuel into the engine compartment every time the primer plunger was pushed. This was adding to the fuel dripping all over the place. So that is the next thing on the list.
    NOTE: The IA who installed my new aluminum tanks was not the IA who last tinkered with the carburetor.
Name:	Carb float flooded 2.jpg
    Likes jrussl, 180Marty, skywagon8a, BC12D-4-85, DENNY liked this post
    cubdrvr's Avatar
    Jan 2002
    1,502
    Preflight when cowling open I give a tug on each primer line..........they have a tendency to break off in the fitting that's not visible.
    Likes Captain Ron, kestrel liked this post
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,262
    Cubdrver
    The fitting going into the cylinders were just fine. The major spraying leak was up above the carb behind the engine. Somewhat concealed.
    The is a splitter fitting that sends gas from the one line off into port and starboard directions. When I pumped the primer it was spraying 5 inches out of the fitting.
    You had to have somebody pump while you look. It was a nice mist. Perfect to start a friggen fire.
    Likes Scott A, DENNY liked this post
    3,206
    I had my primer line brake at the T behind the engine last fall. What a major pain to fix.
    Apr 2009
    AK
    396
    Hope you got an Avstar brass float. The blue Marvel ones aren’t super consistent, apparently. Had a weird lean range on a fresh c-90 carb from Marvel, sent it back to them, came back the same. Talked to a highly experienced carb repair station up here, and was told to throw the Marvel float in the trash- apparently he sees this commonly. I didn’t listen the first time, gave Marvel a chance to warranty it, but after the second go-around, I put the Avstar brass float in, and totally cured. Anyone else heard of issues with these? And no, it wasn’t cracked or sunk…
    Likes mixer liked this post
    Vermont
    430
    If it wasn't cracked or sunk, it might be like my old plow truck, where a composite float distorted and rubbed the inside of the chamber. What does Marvel say about mogas?
    What's a go-around?
    12,748
    Quote Originally Posted by ak49flyer View Post
    What was the “weird lean range” you noted?
    Apr 2009
    AK
    396
    Missing at mid-range, particularly while running on only one mag or the other during a check. Carb heat would almost cure it completely, but the float did away with it entirely. Spent days troubleshooting, finally swapped carbs with another to conclusively rule out anything else, and it was indeed the new carb from Marvel.
  1. My darn carburetor started leaking
    By Alex Clark in forum Piper: PA-12 Super Cruiser
    Last Post: 04-18-2023, 12:12 PM
  2. Leaking Carburetor
    By mvivion in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 02-07-2021, 12:01 PM
  3. P40 discovered in Sahara desert
    By cruiser in forum Cafe Supercub
    Last Post: 05-14-2012, 11:54 AM
