Thanks Thanks:  0
Results 1 to 11 of 11
Thread: Float Strut lengths PA-12 with 18 style gear compared to 18 gear?
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,267
    I have some EDO 2000s which I never installed.
    They are supposed to be for a PA-12 with PA-18 style gear legs.
    I am going to sell the plane and floats. ( Gotta find something more bad hip friendly)
    [B]How much difference, if any, is there between the struts for a PA-12 with 18 style gear and a regular PA-18 strut set-up?
Name:	019 (1280x960).jpg
    4,715
    Eddie Peck would know. FWIW I had a PA-12 with -18 gear and -18 struts + fittings worked great on the 2K's. Some tabs needed for the X wires.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,267
    I will give that a try.
    Just measuring without anyone to help hold the other end of the tape, I came out with the following on mine
    BOLT TO BOLT
    28.5 inches for the rear struts
    50.5 for the diagonal strut
    35.0 inches for the forward strut
    and 67 inches for the spread bar bolt to bolt.
    4,264
    When I converted my -12 from stock gear to -18 gear the forward gear pivot points did not change. I only had to add the cabane attachments.
    8,717
    When I put my -12 on EDO 2000s I bought floats from an -18 and had them installed on my -12. When I sold those floats they went back onto an -18. I don’t recall any talk of modifying the strut lengths. Not recalling isn’t a solid answer but I usually remember details like that.
    13,237
    Isn't there an -18 there which you can measure? All the 2000 spreaders are the same. A difference would be the length of the cross wires and/or their wire pulls due to the width of the fuselage.
    Your rear struts are very short... have they been cut down? I have Citabria struts on my Cub and the rear one is 31-7/8". I lengthened it to 33" for my installation.
    NX1PA
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,267
    Well, I found a couple sets of EDO 2000s set up for PA-18s and another set in town that are on a PA-12 with 18 style gear.
    My measurements are the same as the other PA-12.
    The PA-18 set-ups are narrower, and have different length struts.
    13,237
    What do you mean by the PA-18 set-ups are narrower? All of the 2000 floats came from EDO with the same spreader bars for all the different installations. The early PA-12 had a welded steel truss which was changed to the same style of struts as the other planes. This is not what you have.
    The part numbers for the PA-12 struts are front 89-S-181, diagonal 89-S-144, rear 89-S-182
    The part numbers for the PA-18 struts are front 69475, diagonal 69476, rear 69477
    I don't have the dimensions. Your rear strut seems short, as though someone has shortened it to give the -12 a higher angle of attack.
    NX1PA
    May 2020
    Michigan
    57
    Quote Originally Posted by Alex Clark View Post
    Are the floats in Alaska or lower 48?
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,267
    I meant that the PA-18 is narrower than the PA-12. Not the floats.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,267
    In in the hills above Homer Alaska....
  1. Gear Strut differences
    By Farmboy in forum Modifications
    Last Post: 11-15-2017, 01:14 PM
  2. Attach mtn bike to strut? Gear leg?
    By tedwaltman1 in forum Cafe Supercub
    Last Post: 03-11-2015, 09:16 PM
  3. Replies: 9
    Last Post: 03-02-2005, 03:35 AM
