Results 1 to 20 of 20
Thread: New brake lines
    Dec 2011
    Caldwell, Texas
    215
    New brake lines
    Bought some 3 inch extended gear and looking for best ideas for new brake lines.
    What I'd like to do is use some Aeroquip teflon lined stainless steel braided hose with appropriate fittings, and make a ONE PIECE line from master cylinder to caliper.
    The gear legs won't be covered and I think this will be the best look and function, but not sure about the "acceptability"
    Certified Cub
    Thanks!
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,417
    Sounds very similar to a standard CubCrafters installation. Why wouldn't it be "acceptable".
    Dec 2011
    Caldwell, Texas
    215
    Forgot to mention its a certified cub. Waiting to see what the STC says about the brake lines if anything.
    8,336
    My exp Cub’s brake lines are from a local hydraulics store, made to my specs. I wouldn’t hesitate to do the same on a certified Cub.
    Likes Helmetfire, DENNY, Rob, Scooter7779h liked this post
    Rob's Avatar
    Nov 2002
    AZ06
    872
    My certified cub wears exactly what you want. I made them just long enough to switch between my 6" gear and my 3" gear because I thought I might like the shorter gear better on 35's (I don't).
    The odds of a local hardware store in AK having appropriate hose and AN fittings is probably much greater than a local hardware store in most L48 locations. However there is another path to make the cost, wait times, and location, more acceptable than the standard aircraft big box supplier.
    Almost any agricultural area will have a hydraulics shop. Here in the SW we use CSC, A lot. It's a ParkerStore (Parker Hannifin) and 99% of the time they have the appropriate hose and AN fittings in stock and will produce a hose to my specs while I wait. They will also have the appropriate O-rings (minus the gold plated price) for any of those needs, provided you have a mil-spec #, as they don't speak aviation in most locations. I would not plan on having them made at a local 'speed shop' as the fittings will not likely be AN (or the correct angle) and the hose will likely be a cheap Chinese braided look alike.
    It would appear that the closest one to you is Wilson Company in Addison, I know nothing of them, but it'd be the first call I made, after verifying on the Parkerstore website location tool.
    Take care, Rob
    PS, if hydraulics speak is new to you, pull off one complete assembly mess, take it with you, and explain that you want to clean the mess up.
    Thanks jrussl, Helmetfire thanked for this post
    Likes DENNY, Helmetfire liked this post
    8,229
    Agree with Rob. For authority, see AC 23.27. Should be no problem with a competent IA.
    Likes DENNY, jrussl liked this post
    jrussl's Avatar
    Jul 2005
    Madison, WI
    910
    Rumor has it that these guys make great hoses that last many years. Ship next day.
    https://www.pegasusautoracing.com/gr...GroupID=PLUMAN
    8,336
    Caldwell must have a hydraulics shop with all the tractors in the area. If not? There are a handful in College Station and Bryan. They likely won’t have AN flare fittings but will have steel fittings that are compatible. What you need to look at is whether you want straight, 45°, or 90° fittings to best route the lines.
    Likes Helmetfire liked this post
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    996
    Quote Originally Posted by jrussl View Post
    I use those for almost 10 years. Very good quality.
    https://www.pegasusautoracing.com/pr....asp?Product=3
    Dec 2016
    Canyon, tx
    1,117
    Summit Racing is about as easy as it gets. -4 reusable fittings to your liking. If you mess up on your order it’s probably not a day or two shipping from their Arlington warehouse. Easy deal once you figure out what fittings you need. Don’t over think it and there are videos to show assembly.
    10,013
    One reason most people keep the connection on the underside of the belly is if you go to floats or damage the line it is quick and easy to remove and cap, or remove and replace.
    Likes DENNY, skywagon8a liked this post
    8,336
    Bulkhead fittings make life easier for any gear reconfiguration. I’d never do a Cub without them.
    Likes Scooter7779h, alaskaoe liked this post
    22,674
    I make my own brake lines using Aeroquip fittings and Teflon hose from Summit Racing.
    Fittings https://www.summitracing.com/parts/AER-FBM1100
    Hose https://www.summitracing.com/parts/AER-FCC0303
    Attached Files Attached Files
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    880
    I've noticed that the single teflon line adds a tiny bit of a spongy feel to the brakes, versus the hard line with 303 hose. No effect on the effectiveness, just the feel. Neither good nor bad, just different.
    8,336
    Here are a few pics of my lines. My brakes have an AN 90° fitting and the line has a straight fitting. At the fuselage I have a 90° bulkhead fitting. Measuring for external lines was easy. It took me a few tries to get the inside lines right because of routing blind under the floor. The 45° end was from one of the failed attempts. Put chafe protection where the lines might rub on other surfaces.
ID:	65175   Click image for larger version.
ID:	65176   Click image for larger version.
ID:	65177   Click image for larger version.
    Thanks Helmetfire thanked for this post
    Likes jrussl, Helmetfire liked this post
    Scott A's Avatar
    May 2007
    Park City, UT
    124
    Ah, I welded in a tab for bulkhead fitting in that exact location for brake line exit (out the side then 90 degree down). Wasn't sure how it would work but looks like it does just fine. I made metal belly pan and there just wasn't a good way to get the lines through without having to mess with a brake line every time. I was worried about someone putting a foot on it getting in our out - but I think the open door stops just above it and sort of protects it (?)
    EDIT - Not to hijack but I also noticed EarthX - mine is in the exact same position - then I read the manual - " Installation of the battery in the cockpit is not recommended unless the battery is properly vented overboard." Hmm.. I contacted EarthX and that quote is mostly required by the lawyers, with all the safety features etc. not ever (probably) going to be an issue - no need to respond here and mess up brake thread - but we don't seem as anal here about that as some other sites I've been on
    8,336
    Venting a battery that doesn’t off-gas is pointless.
    Likes Scott A liked this post
    8,229
    Not venting a battery (or anything else) in a Cub cockpit is impossible.
    Likes 68Papa liked this post
    8,336
    Quote Originally Posted by Helmetfire View Post
    Certified Cub
    Thanks!
    Helmetfire,
    Did you get your lines squared away? I’ll be driving through Caldwell in a few and thought about you.
    SB
    Dec 2011
    Caldwell, Texas
    215
    Helmetfire,
    SB
    Dang just missed you! Didn't realize you were around here.
    Yes, been busy so haven't updated...I ended up using the Aeroquip -4AN SS PTFE lines with their removeable fittings. I've used the same setup in the past and its worked great and I remembered I had some leftover so it worked out nice. Only trouble I ran into was that I couldn't fit the fitting through the hole in the gear leg reinforcement, so I had to assemble one end of the line after feeding it through which was no big deal really. Having trouble downloading pics at the moment so I'll update when able.
    If you're gonna be around this area send me a PM and lets meet up sometime! Always down to meet a fellow super cubber...the Caldwell airport is pretty dormant, not much going on here!
    aaron
  1. Brake Lines
    By TxAgfisher in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 03-06-2021, 08:06 AM
  2. Brake lines for a PA-12
    By Pundy in forum Super Cub Sick Bay
    Last Post: 05-16-2013, 10:57 PM
  3. Brake lines
    By Bugs66 in forum Experimental Cubs
    Last Post: 04-08-2008, 04:45 PM
  4. brake lines
    By skysigns in forum Cafe Supercub
    Last Post: 11-23-2005, 12:26 PM
