Thanks Thanks:  0
Results 1 to 17 of 17
Thread: oil cooler
    Jun 2009
    11
    oil cooler
    I have a 90 on my pa11 with oil temp issues has anyone installed a oil cooler?
    12,944
    [QUOTE=darenlhr;843628]I have a 90 on my pa11 with oil temp issues has anyone installed a oil cooler?[/
    Do you have the blast tube blowing on your oil temp bulb?
    Waldo M's Avatar
    Jan 2018
    Finger Lakes area, western NY.
    217
    What mvivion said. When we switched from an A-65 to a C-90 on our PA-11, I was able to get the conversion drawing from Piper. I call it the poor man's oil cooler. [The A-65 doesn't need the extra cooling]
    Part of Piper's C-90 installation involves an aluminum box covering the oil screen housing that accepts an air drive scat tube for cooling. The other end of the scat tube attaches to the aft left lateral engine baffle. Univair will be happy to sell you the aluminum box and probably the fitting for the baffle.
    Use a fly cutter to make the hole in the baffle, rivet a fitting for the scat tube on the back side, and you're in business. It may look like a Rube Goldberg arrangement, but it works. We have never had a high oil temperature issue with the airplane. The one complication the box adds is that it's a challenge to run the safety wire from the oil screen though the box and across the accessory case to the acorn nut on the oil pressure relief valve. You will run through your whole vocabulary of cuss words twice the first couple times you do this.
    Jerry Burr's Avatar
    May 2002
    Sedro Woolley, Washington.
    723
    The blast tube was more to make the fed happy than anything else. It doesn't change the oil temp at the inlet. I posted test results years ago. Maybe someone can find them. The oil temp at the oil filter / oil cooler bypass stays the same with or without the blast tube. Makes a big difference on the gauge however. Jerry
    Likes skywagon8a, BC12D-4-85, Steve Pierce liked this post
    Mar 2009
    21
    Check your Mag timing.
    Jul 2009
    88
    A cowled small continental engine shouldn't run hot in average temperatures unless there's some other reason.Does temperature rise slow or fast?
    12,944
    Quote Originally Posted by dirthog4 View Post
    There is likely nothing wrong with that engine. This is standard on C-90s in PA-11s, at least. As Jerry noted, the blast tube doesn’t do anything to actual oil temps. But the sensor is located at the worst place in the system. The last tube cools the sensor, so oil temperature readings stay within limits.
    The oil is not that hot, actually. I suppose if you could relocate the sensor…..
    But install the blast tube, and go fly.
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    191
    I had the same issue with my PA-11 with a C-90-8. Instead of putting a blast tube on the oil screen housing to trick the gauge, I took a 2" piece of scat line and routed it to the oil tank as a blast tube. The inlet for it was one of the little outlets just beneath the propeller. It lowered my oil temp at least 20 degrees F. In the winter I take it off so I can get my oil temp to 180 and dump the moisture.
    I did check the oil temp with an infered thermometer to verify my oil temp gauge was reading correctly. I could tell it was pretty hot as my idle oil pressure was down to 10 psi at 220 degree oil temp.
    A C-90 in a PA-11 will run warmer oil temps if you do not do this. Keep in mind a C-90-8 it is just a 4 quart sump and the accessory housing and oil pump is identical to an A-65 so you will run a lower oil pressure than if you have a C-90-12.
    Javron L-21
    Clip-wing Taylorcraft
    4,713
    Some flying C-90's use Cessna's C-140 under crankcase and oil sump baffling. It can be adapted to other aircraft. It takes cold inlet air from the nose bowl, directs it under the crankcase then down the front of the sump. Look for Cessna's parts diagrams or contact https://www.airforms.biz/index.php?r...product_id=622. I have that setup on my Taylorcraft as the engine came from a C-140.
    Jun 2009
    11
    I do have a blast tube on the bulb the plane was restored in 2010 new everything
    Jun 2009
    11
    My idle pressure also gets low when it’s hot
    13,237
    Quote Originally Posted by darenlhr View Post
    What do you mean by oil temp issues ?
    The maximum limit is 225 F.
    https://drs.faa.gov/browse/TCDSMODEL...dalOpened=true
    Is this something which just recently appeared?
    Oil pressure normally is lower at idle when the temperature is warm. The pressure limits are: 30-60 psi. Are you within limits?
    If this is something which just recently happened, have you pulled the oil screen to look for anything which shouldn't be there?
    NX1PA
    Jun 2009
    11
    It’s always has issues I’ve tried the blast tube on the oil tank with zero luck it will get up to 235 on a 80 degree day it will reach 220 redline in 15 minutes after takeoff and slowly climb to 235 if I run around at 2200 rpm it will stay at 220. The temp prob and guage are spot on. I do have a airwolf remote oil cooler which putts the oil sender 2 inches above the exhaust. Maybe that’s kicking out enough heat to make it read high. Oil pressures at 60 when first started the goes down to 30 at 220 idle after landing around 8 psi it’s to bad I couldn’t machine a spot on the case like the 90-12 for a tempest remote filter then use steves aircraft oil cooler
    White City, Oregon
    1,008
    If you have the Airwolf remote oil filter system you can still use our oil cooler STC. The biggest issue is Airwolf uses a long mounting stud for the filter that can interfere with the stud installed in our diverter prohibiting it from sealing properly. You would have to shorten the stud in Airwolf’s part, voiding any warranty they may provide.
    —Brian
    Jun 2009
    11
    Do you have 3/8 lines for the cooler Brian
    White City, Oregon
    1,008
    No, not a certified hose shop.
    Plus, too many variables for length to have them pre made. The oil cooler can be mounted anywhere on the firewall. The BOM lists hose type and end part numbers for making hoses to fit.
    —Brian
    Jun 2009
    11
    The smallest cooler I could find from aero classics is 3/8 do you know of any with 1/2
  1. Replies: 8
    Last Post: 06-18-2012, 04:34 PM
  2. PA-12 Oil cooler 337
    By Amery1836 in forum Modifications
    Last Post: 04-04-2009, 11:25 AM
  3. Oil Cooler
    By supercub88 in forum Modifications
    Last Post: 04-05-2005, 11:50 AM
