Results 1 to 12 of 12
Thread: Identifying brakes
    Aug 2020
    68
    Identifying brakes
    I’ve not seen enough brakes on cubs with labels to become proficient at identification. Does anyone have a simple way to ID what type of brakes are on a plane?
    Marty
    Aug 2020
    68
    Different set
    3,210
    First one looks like a 1 1/2 inch axle dual puck and second one is 1 1/4. However some of the grove 1 1/2 don't have the nipples on the back do the wheels have any ID on them?
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,417
    Quote Originally Posted by akmarty View Post
    Well my bet for this one is Cleveland 30-52.
    May 2021
    Arizona, USA
    1,417
    My bet for the second one is a Grove 35 series.
    8,341
    Aug 2020
    68
    Wheels are 6” ABW in both cases.
    Aug 2020
    68
    First set came off 1.5” gear and second is installed on 1.25” gear.
    3,210
    The six bolt magnesium wheel with 1 1/4 axle/brake is what the cool pilots fly. They are 2.5 lbs lighter per side than the 1 1/2 aluminum 3 bolt wheels. Lots of mix and match going on usually just depends on what was around for the last rebuild. The big question is what axle do you have on your gear.
    Aug 2020
    68
    My plane has 1.25” axles and the wheels are the 6” ABW. Need to re-line the brakes. One side wore thru to the rivets.
    I just learned that when you get uneven pad wear it is likely that your spacer is incorrect. The inside surface on the plate bushings should be flush with the brake disc or it won’t wear both sides.
    Mine was spaced incorrectly.
    3,210
    I just replaced mine at annual. Stoddards has Grove pads/rivets on the shelf that fit the 1 1/4 brakes. They work fine on Cleaveland brakes. You can also get uneven pad wear if the guide pins are not moving freely.
    10,015
    Disc.
    I am a pilot, what more do I need to know?
    If an owner, you might need to know how many zeros on the check though
  1. Help identifying old skis
    By WWhunter in forum Ski Flying Forum
    Last Post: 11-15-2021, 01:45 PM
  2. Need help Identifying Tool
    By ulpilot in forum Cafe Supercub
    Last Post: 11-25-2015, 03:11 AM
  3. Help identifying what on the trailer
    By Ruffair in forum Cafe Supercub
    Last Post: 10-06-2015, 10:43 AM
  4. Help Identifying Parts
    By Roger Peterson in forum Cafe Supercub
    Last Post: 12-10-2012, 01:49 PM
  5. Need Help Identifying Spinner
    By Mush in forum Cafe Supercub
    Last Post: 12-06-2011, 01:58 AM
