DailTragger
ND
Hi, all. I've got a -12 with a -18 tail. Unfortunately, just discovered the main support tube on the LH elevator has broken clear through just outboard of the hinge/stabilizer attach point and needs to be replaced (forgive my phraseology). Discovered the issue on the ground before flying, thank goodness.
So, I'm reaching out to the hive mind to get your thoughts on whether I should save some pennies and try to find a serviceable LH elevator assembly or should I get a new one? If used, should I pay a few extra for a covered elevator or will I just need to tear off the fabric to inspect it anyway?
