Results 1 to 9 of 9
Thread: Oil dip stick
    Oct 2021
    7
    Oil dip stick
    I have an O290-D with standard dip stick and tube. I noticed the same engine that had a much shorter tube and dip stick. I can't find this option in the Lycoming parts manual, was wondering if it is legally available or did someone just modify it.
Name:	oil dip stick.jpg
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,417
    Quote Originally Posted by RedButte View Post
    May or may not be related but my YIO-360 has a 2 part dipstick tube comprising of one long section and one short section. I wonder if the pictured tube is that short section. It's easy to make a dipstick shorter.
    Caution - any question about how to calibrate the shorter dipsick will result in a discussion of whether the dipstick should indicate the quantity of oil in the sump or the quantity of oil in the engine.
    13,023
    The really short ones screw directly into the case without even that short tube.
    NX1PA
    22,676
    Those are pressed in if memory serves me correctly. I know of some that were replaced and PRC was used to seal the tube to the case.
    8,341
    No flats to wrench it in, no safety wire? It must be pressed in. I wouldn’t mess with it. You need a funnel with the longer tube, too. Buy a longer funnel and leave it alone. If you think the case is threaded and want a longer tube? I have a Lycoming tube and dipstick on the shelf. I had to change mine for the Superior sump.
    May 2021
    Arizona, USA
    1,417
    I had only heard of, and seen, threaded dipstick/filler tubes but found the answer in post 5 of this thread -
    https://www.supercub.org/forum/showt...il-tube-length
    These seem to be several different lengths of threaded filler tubes but that won't help if the crankcase is not threaded.
    May 2021
    Arizona, USA
    1,417
    Unthreaded filler tubes are available NOS and used on eBay. I didn't find one as short as shown in the orginal post but they should be easy to shorten to taste. E.g.
    https://www.ebay.com/itm/266063637248
    May 2017
    1,567
    My O-235 has no tube, just screws right into the case.
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    768
    Your memory is correct. I have an O-290-D originally out of a SuperCub apart in the hangar for overhaul now. This one is pressed in.
    -Cub Builder
  1. Looking for a stick disconnect
    By Bud Hartman in forum Products, Purchases, Reviews & Prices
    Last Post: 12-04-2010, 11:45 AM
  2. Broke my stick ( well computer stick) dang it,,,
    By Alex Clark in forum Lighter than Air - Flying Humor
    Last Post: 05-11-2007, 02:51 PM
  3. NWA is trying to stick it to GA.
    By BSEC in forum Take Action Jackson
    Last Post: 12-21-2006, 10:03 AM
