Starting to gather up parts for exp build. Carbureted 0-375. Can’t decide if to stay tried and true Bendix, one Bendix and one Emag or dual Emags. I’ve read till eyes have bleed on the topic. Census seems with Emags it’s starts better and better fuel burn. 1-1.5gph better from my readings. My response to the “starts better” would be that I’ve hand propped for 1000hrs from a c90 to a 0-360 all with composite props. I have never thought they were hard to start once i figured out the engines routine. Better fuel burn of course would be appreciated. The ability to run the cheaper auto plugs a plus as well.
Battery is dead in the bush…no big deal just use a 9v they say. But what does that do for you if the battery is dead and won’t hold a charge (for some reason it isn’t working properly). I know that is a one off scenario but would only take one of those situations to make a crap deal even crappier if a ways from the house. I personally know of several who have had failures on either one or both emags but supposedly that was the “early” ones and problem Was identified and cured..??
Better fuel burn would be my main reason for wanting to get something other than slicks/Bendix. For those of you that have or do run one standard and one emag (I would want to put standard on the left) do you still see the fuel burn benefits with just the one Emag and you can still run auto plugs on the tops correct? I know nothing of these other than what I’ve been reading. Thanks for any info
