Thanks Thanks:  0
Results 1 to 11 of 11
Thread: Fwd Induction vs updraft induction on a new build
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    174
    I have a forward induction (Stock) parallel valve IO-360 and would like to use it in my Javron Super Cub kit. I can obviously swap out the sump for a vertical induction sump but before I did wanted to see if there were any advantages I was missing. As of now, I plan to stick with fuel injection either way. To me, the possible disadvantages of the fwd sump are:
    1) Weight of the actual sumps (maybe?)
    2) Exhaust options limited (I have a Vetterman X over for Super Cub but with no muffs)
    3) Fitment of adequate heat muffs
    4) Air filter/ Intake challenges
    I do like the idea of cleaning up the underside of the cowling a bit.
    I am an AP with several builds/ restorations under my belt so making custom intakes, lower cowlings, heat muffs, etc is a non-event.
    I spoke with an extremely helpful repeat Javron builder that recommended to swap to vertical intake and carb. Just wanted to get a few more data points before I change things.
    Appreciate any feedback!
    Javron L-21
    Clip-wing Taylorcraft
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,417
    Quote Originally Posted by acroeric View Post
    You could take a close look at the CubCrafters 363i engine. It is a parallel valve Lycoming YIO-360 with no induction tubes in the oil sump. This engine uses a carbon fibre induction manifold fed by a horizontal fuel injection servo. Maybe some ideas there.
    CC363i exhaust has very effective cabin heat.
    Likes acroeric liked this post
    Ö
    8,345
    Iím a fan of Superiorís cold air induction, which is forward facing and quite low profile. I have an Airflow Performance 200A injection on mine. My air box is quite large and has to contribute ram air. I canít think of any down side.
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    174
    I weighed the engine driven fuel pump and the boost pump (Airflow Performance) and came up with 5.75 lbs. The Carb and the servo/ flow divider are about the same weight. I know there will be a little more plumbing for fuel injection but I could eliminate carb heat so that may be a wash. Weight is something I want to manage carefully from the start. To me, fuel injection is worth the 6 pound hit.
    I wonder if a fwd induction sump on a parallel valve engine really is heavier than a vertical?
    Appreciate the intel and pics. Those help a bunch.
    Javron L-21
    Ö
    8,345
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    174
    Yep- had that on my Pitts and the Murray's are like family to me. We have done several projects together over the years. Good people. Not sure what the lead time is on those right now and the cost is a deterrent until I explore some other options.
    FWIW- this is the current sump I have. Not my engine (or pic) but mine is identical. Thanks to the Vans Resource center for the picture.
    Javron L-21
    Ö
    8,345
    My engine came with that sump. I think the height is very similar to the Superior, so fitting it should be simple enough. I’d bet Clint has an exhaust design for it. FWIW I use the dual exhaust with dual mufflers and it sounds great. With both feeding cabin heat boxes I have lots of cabin heat available. I dump both to the front seat but it’d be easy to have a dedicated rear seat heat box.
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    174
    I actually have the Vetterman exhaust for this set up but without the mufflers. I bet I could send it back and have them added. For sure would be the most direct route.
    StewartB- what does your air filter look like? I would go with something really simple that I could bypass easily when in flight
    Javron L-21
    Likes mixer liked this post
    Ö
    8,345
    Now thereís a topic! How to fit alternate air was a project. The FI Cubs I know donít have it so I didnít have anything to model after. We put a door into the back wall of the airbox and that meant using an air filter with a big enough footprint to cover it. Most guys just put a cone shaped K&N filter on.
    My air box sits between dual oil coolers.
    May 2021
    Arizona, USA
    1,417
    CubCrafters FX-3 has alternate air but no alternate air control. A spring biased door opens when the primary air path is blocked. When that door opens unfiltered air is drawn over the front right exhaust stack.
    Ö
    8,345
    Acroeric, it took awhile to find these pics. Here’s my alternate air closed and open. And for the critics? When I swapped the engine I did use a metal locking nut!
    Honestly? If I was building another FI Cub I’d use a cone filter and skip the alt air. Mine’s a day VFR airplane. A fouled filter is hard to imagine. I’d still make the collector big enough to utilize ram air.
ID:	64558   Click image for larger version.
  1. Cold Air Induction
    By supercub83a in forum Modifications
    Last Post: 10-06-2021, 01:03 PM
  2. Wrench to remove Continental C-90 Induction Elbows
    By sdischer in forum Tips and Tricks
    Last Post: 02-19-2020, 03:31 PM
  3. Silicone Induction Connector Hose C-90
    By Grant in forum Super Cub Sick Bay
    Last Post: 08-17-2015, 02:53 PM
  4. Cold air induction
    By diggler in forum Modifications
    Last Post: 08-28-2003, 09:42 AM
