Results 1 to 13 of 13
Thread: N Number location and who makes best graphics
    Aug 2021
    8
    Looking for opinions, that should be lively, on 3 inch N number location. Fuse, rudder, etc. Who should I consider ordering the number graphics from?
    8,156
    Any local sign shop should be able to cut vinyl letters for you in lots of colors and lots of fonts.
    Likes CubCruiser liked this post
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    933
    Jan 2017
    PNW
    225
    If you want to paint the numbers on the local sign shop can also cut you a paint mask. Very easy to use, just stick it on, paint over it and peal it off.
    location…mine are above the horizontal stabilizer, kind of at the base of the vertical stabilizer. A friend put his on the rudder in a position that lined up with a neutral elevator position. I watched a video of him departing and couldn’t see the N number until I watched it in slow motion. So, location depends on motivation…and of course compliance with your countries regulations. Motivated by anonymity…get creative.
    Also, anything that says “aero” or “aircraft” adds a couple zeros to the price. When I did the checkerboard on my tail the quotes from aircraft graphics outfits were between $800 and $2000. Sign shop was much more reasonable. They cut me a paint mask…worked great.
    22,471
    I use Aerographics and like them above the horizontal stab, harder to see from the ground. I know someone who was flying low and inadvertently flew over someone's horses and was accused of scaring these prize horses so bad they would no longer breed. Turned into a $%&* show.
    1,521
    Suggest you read 45.21, 45.22, and 45.25. 45.25 provides the location requirements.
    Dec 2016
    Canyon, tx
    1,108
    I deal with a lot of horses with PTSD. Some of it might be caused by me Interrupting breeding!? I’ll have to survey a few today and see what they say.
    Aug 2015
    AK, ME - what time of year is it?
    843
    Are you planning on flying through an ADIZ?
    https://www.faa.gov/air_traffic/publ...ions/airspace/
    https://www.law.cornell.edu/cfr/text/14/45.29
    Quote Originally Posted by smilinjack View Post
    Jan 2013
    47
    Quote Originally Posted by JohnnyR View Post
    if your 135 you need 12 inch numbers
    cubdrvr's Avatar
    Jan 2002
    1,475
    "I use Aerographics and like them above the horizontal stab, harder to see from the ground."
    Correction Pierce..........."unable" to see from the ground
    Aug 2021
    8
    Thanks, this is very helpful.
    Jan 2017
    PNW
    225
    You can get temporary vinyl 12” numbers to stick on for a trip requiring them and peal them off when no longer needed.
    Likes AZinAK, kestrel, JohnnyR liked this post
    4,106
    Quote Originally Posted by Mr. Ed View Post
    I've even seen guys use masking tape for those temp 12" numbers.
  1. Husky Airframe Number Location
    By wpbrady in forum Cafe Supercub
    Last Post: 12-17-2012, 08:52 PM
  2. serial number location
    By FirstCruiser in forum Experimental Cubs
    Last Post: 03-14-2007, 08:52 AM
  3. serial number location
    By JB3 in forum Cafe Supercub
    Last Post: 01-29-2004, 10:09 AM
