Results 1 to 7 of 7
Thread: Pa-11 Engine mount problem
    Jan 2023
    2
    I recently bought a experimental Pa-11 with a O-200A on the preinspection the lower lord mounts looked worn out after replacing they still didn't look right the lower mounts seem to be around 3/16 s off from lining up is this normal. If not can someone tell me the center to center measurements of to top mount to bottom mount. First pic is new mount installed 2nd Pic is old mount.
ID:	64537   Click image for larger version.
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    420
    No it’s not normal. You should do a good visual inspection for bent tubes. Is the engine mount Piper stock or homemade or no idea? Did you install a new mount or just change the rubber vibration isolators? I might have a NOS mount in the hanger. I’ll look.
    PA-12 N418BS
    22,479
    Relax the weight of the engine weight with an engine hoist and determine if everything lines up properly. Sounds like a misaligned mount but it is hard to see the new mounts in the first picture.
    Likes tempdoug liked this post
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,320
    New mount:
Name:	new mount.PNG
    Jan 2023
    2
    The engine mount was custom made with zero thrust line like a J3 with heavier tubing for the O-200 . It was made by Aero fabricaters Inc around 2011. Both bottom mounts are misaligned. Thanks for all replies!
    Likes AkPA/18 liked this post
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    755
    It appears the top mounts line up with the engine mount bosses and the lower mounts don't. The mount needs to be jigged, then cut and welded to fit properly. Unfortunately, that's not unusual from Aero Fabricators.
    You just hit the nail on the head. It was made by Aero Fabricators. I've never bought anything from them yet that was usable without cutting it apart and re-welding back to spec. The Dynafocal mount I bought from them for my SC Clone had 10° nose down and was built as a mirror image from the plan. I cut it apart and welded it back together to build to spec. The "stock" SC exhaust I bought from them was so far out of whack it was impossible to actually bolt it up to the cylinders. That went back for a refund. Their welding seemed to be acceptable, but their jigging is terrible, or non-existent.
    -Cub Builder
    11,557
    Wagaero/aero fabricators, almost just right or years
  1. engine starting problem
    By btoneyak in forum Tips and Tricks
    Last Post: 04-24-2015, 06:35 AM
  2. O320 Engine problem
    By oliveros in forum Cafe Supercub
    Last Post: 09-01-2013, 11:50 AM
  3. Engine Problem
    By bryan in forum Super Cub Sick Bay
    Last Post: 05-19-2010, 05:18 PM
  4. Engine Mag drop problem
    By Fortysix12 in forum Experimental Cubs
    Last Post: 05-03-2010, 09:17 PM
