Imagine a simple circuit with a single light connected to a single battery. Electrons will flow out of one battery terminal, through the light bulb, and back into the battery through the opposite terminal from where it started.
Now take that same circuit. Install a switch in the wire between the battery and the light bulb. Then cut the other wire and connect each cut end to a steel tube. Got that? In this case, the only way the bulb will light up is if the switch is 'closed'. In effect the switch reconnects the wire. So now the electrons will flow from one battery terminal, through the closed switch, and to the bulb. after the electrons exit the bulb they will flow through that wire and into the steel tube. From the steel tube, they will flow back to the opposite battery terminal through the other cut wire.
The path of electrons will not change from the first example to the second. The electrons still exit the battery, go through the bulb, and return to the battery. But in the second example, we've installed a 'common ground'. One battery terminal is connected to the steel tube, and one wire from ALL bulbs installed may be connected to that tube at any point. The opposite wire from battery to bulb now has a switch installed. The switch makes a mechanical connection between the cut ends of a wire. When the switch is 'open' the wire ends are held apart from each other and there is no path for the electrons. But when the switch is closed, the ends of the wire are touching and electrons will now flow through the wire.
In an aircraft the battery from above will have the negative terminal connected to the airframe. This means that when we install an electrically powered item, the negative wire from that item only needs to be connected to any part of the airframe. The positive wire from that item will connect to a switch, which in turn, will be connected to the positive battery terminal. This is simplified but it should shed some light on how the power distribution works.
