Results 1 to 21 of 21
Thread: PA-18 Landing Gear V Drawings?
    May 2020
    Michigan
    38
    Does anyone have an image of the landing gear (either side) for a PA-18? Photo of the J5 version with dimensions attached as example of what I am seeking.
    Im trying to verify that the PA-18 landing gear will match the attach points on the J5. The J5 has a 5/16 bolt, same as a 1750 gross PA-18. Click image for larger version.
Name:	Screen Shot 2023-01-22 at 12.01.40 PM.jpg
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    442
    Christian Sturms site has a good set of drawings. http://www.supercubproject.com/drawings/main.aspx
    We put a set of -18 gear on our J3. Bolted right up.
    Wayne
    Thanks General thanked for this post
    8,147
    Memory is getting fuzzy, but I think Univair advertises its J3 gear leg as suitable for J5 and PA-18.
    I'll check back later and if no one else has, I will post the drawings I found for my on-going quest for Cleveland approval on the J5.
    8,147
    Well, it is in my files as a pdf, but I cannot get it to reproduce here, so just google the Piper part number. This is a 1941 drawing, but I have the PA-18 drawing stored somewhere, probably also pdf. Looking. Also, the PA-18 gear leg drawing is #10033, and you might be able to find it on the internet. I did, and printed it up for my field approval application, but cannot find it. Possible that it is in the Cleveland 199-01700 kit instructions - I will look.
    Attached Files Attached Files
    8,147
    Nope - cannot find it. Hard copies are at the FSDO, still being ignored. It is out there, and can be copied.
    May 2020
    Michigan
    38
    Quote Originally Posted by flybynite View Post
    Wayne
    Exactly what I needed! Thank you!
    4,922
    Try this.
    22,481
    PA18 and higher gross weight J3 uses the same landing gear with 3/8" bolts.
    4,112
    .... my on-going quest for Cleveland approval on the J5.
    Dunno just which cleveland brakes you're trying to get approved,
    but my old Univair catalog states that cleveland w&b kit # 199-071 is approved for "J-3 through PA-20".
    8,147
    The actual STC documents leave out the J4 and J5. No idea why. Been on the aircraft for a quarter century.
    May 2020
    Michigan
    38
    I installed Grove wheels and brakes. They have worked great.
    8,147
    Me too - but this is not my aircraft. I am just trying to make it legal. I shouldn't have to force the owner to buy a $3000 kit.
    May 2020
    Michigan
    38
    Why not just do it via 337?
    supercrow's Avatar
    Dec 2008
    654
    Quote Originally Posted by General View Post
    A 337 will be fine as long as you have approval from an STC or a field approval before filling it out. If by field approval the FAA approval box has to filled out. 337 can be done for major repairs but alterations need prior approval.
    May 2020
    Michigan
    38
    Quote Originally Posted by supercrow View Post
    Yeah, I've become familiar with the process of late. 337's for PA12 wings, belly pod, baby bushwheel, etc this year. For the brakes you have, I'm pretty sure there is a pre-existing 337 for them that can be referenced.
    4,112
    That doesn't always help.
    I got a FA for 26" Goodyears on my C180 a couple years ago--
    even though I had scads of previously approved 337's,
    it still took 11 months and a lot of prodding the FSDO guy.
    Needless to say, this process didn't improve my opinion of the FAA.
    8,147
    Yes - a huge percentage of IAs do not understand 337s. I am not a full time mechanic, but still I see bunches of 337s for alterations approved by IAs. This one is just the latest.
    It says "installed Cleveland . . . Per Piper kit 199-0170 (from memory)". Then it is signed by an IA - in 1996. Scottsdale FSDO accepted it, without stamping block 3, and sent it to OKC.
    Working on approval since May. World's easiest field approval. Dave would do it for free, but this is something the FAA should do - their guidance says "sign it."
    May 2020
    Michigan
    38
    I'm sorry to hear that. We've got a great FSDO where I am. They are good about working with AC owners and feel a responsibility to help them keep these things in the air.
    May 2017
    1,526
    Bob, look over AC23-27 closely! While not very clear, the lead section indicates it is approved data. There is a later section that says you can use STCs that may not have your aircraft on the AML, but are similar. Unfortunately there is another paragraph that says the data can be used to obtain further approval. Clear as mud, but there may be something there that will help you out.
    22,481
    Had a J3 with a C-90-12 engine that was done many years ago on a 337 but no FAA signature. Called the FSDO and they said it was in the permanent records it was fine. got it in writing and put it in the logs.
    8,147
    Yes - my PMI said the same thing. I asked him to put that in writing and he agreed. That was six months ago - he doesn't check his e-mail, but he is a good guy. The guy he assigned to do the approvals is "different."
    I would be happy with an FAA signature acknowledging that the old 337 is approved data. As far as I can tell, that is as good as a stamp in block 3.
  1. PA-12 standard landing gear legs drawings with dimensions
    By Philly5G in forum Piper: PA-12 Super Cruiser
    Last Post: 01-18-2021, 01:14 PM
  2. Any drawings for 3" extended gear??
    By Iflylower in forum Modifications
    Last Post: 01-05-2009, 11:42 PM
