Results 1 to 14 of 14
Thread: Flat light recomendations
    Oct 2014
    2
    Question Flat light recomendations
    Wandering if anyone has any suggestions or ideas for sunglasses and or lens colors that would help with flying/ landing on those flat light winter days? Any suggestions would be appreciated.
    11,557
    Quote Originally Posted by Hardhead View Post
    Those cheap Blue blocker glass worked when ridding a sled. Red lense safety glasses they sell at TSC work for flat light and a little advantage when scud running
    9,991
    Glenn is correct. I have amber glasses I wear, they have a coating that is a tad better than most I have tried.
    Higher quality glass is often better than cheap Tractor Supply safety glasses
    Sometimes staying home is the best option fyi.
    Likes Colorguns liked this post
    12,655
    IF there is enough light for colored lenses, I found that Serengeti’s worked well all year. They darken in brighter light.
    But true flat light is nothing to trifle with. I was taking a recurrent flight check in a 185 of skis near Fairbanks, mid winter. Really low sun line and light snow.
    Check Airman pointed out a lake and told me to land there. I looked it over and put down trackside , came back around and landed the tracks. Check pilot said, okay, taxi back and takeoff same direction I’d landed. I did, turned around and as we approached the next turn around, my heart sank. Not many feet to the left of my approach was a huge beaver house.
    Neither the Check Airman nor I had seen the thing as we were landing. We figured that was enough pioneering for the day and returned to civilization. In twenty winters in FAI, I became VERY careful of “flat light”.
    it really depends on how far north you are in AK. But if very far, be VERY careful if landing off airport (or on airport, for that matter) in mid winter, pay really careful when off airport. True flat light can be really scary stuff.
    Likes stid2677, DENNY, BC12D-4-85 liked this post
    4,416
    Simplest are amber colored shooting or snomachine/skiing lenses.
    These are the traditional flat light glasses and color> https://www.vintagesunglassesshop.co...mbermatic.html While they do work as promised outdoors, the windows in cockpits don't pass the required light spectrum to make them darken much in flight.
    Today they offer these photochromic (or transition) lenses in plain or prescriptions> https://rx-safety.com/2013/10/transition-brown-vs-grey/ I've used the brown models as trifocals year round for a long time, and find them to work well in flat light. If in bright sun then something like B&L's G15 dark lenses filter better and are easier on the eyes.
    Be careful with vertically progressive prescription lenses like Varilux when flying. While easier than bi or trifocals, they can offer blurred images when quickly looking off center w/o moving your head.
    Thanks 68Papa thanked for this post
    Likes stid2677, 5191H, OLDCROWE liked this post
    4,416
    Another aspect of flat light is sunlight direction relative to flight. Surface irregularities create shadows providing the light is strong, not axially scattered too much by low clouds, or not obscured by precipitation. If landing with the Sun's rays shadows may not be seen..they're on the other side of any bumps. Fly around in a circle over the intended LZ and see if lumps and bumps are more pronounced in a certain direction. Forget polarizing lenses as they give a lack of surface definition on snow and water.
    Here's a tragic CFIT on Alaska's North Slope in flat light with cloud cover. Hight time pilot turned and hit. Passenger survived. Note the dry grass but lack of horizon definition. The shore of the dry lake bed is dimly visible in the distance.
Name:	Jim Webster went West 5:14:20.jpg
    Likes stid2677 liked this post
    Speedo's Avatar
    Jul 2002
    TN
    1,850
    Here’s an earlier thread on Method 7 glasses and flat light. When I was flying in the Y-K Delta I tried several different types of glasses and found those with a rosy-brown tint worked best for me. Blue blockers were good but not as good. Vuarnet glasses were developed in France for skiing, and some of their lenses do very well in flat light. Although I’ve not used them for flying, I suspect they’d do very well.
    While we’re on the subject of glasses, these days I’m flying a PC-12 and using a pair of progressive lenses which have been specially tinted by Sky Sight Vision. The upper part and sides of the lenses are tinted, while the rest of the lens is untinted. This makes it significantly easier to read the panel instruments and approach plates, yet you still get good relief from bright sunlight.
    Speedo
    Likes stid2677, BC12D-4-85, Randy, 180Marty liked this post
    Oct 2014
    2
    Thank you guys for the tips on what may work well. I appreciate the help trying to improve my bag of "tools", and the reminder the best tool I have is good decision making. I will look into your recommendations.
    Aug 2019
    ANC
    234
    I'm interested in a good pair of winter flat light glasses too - it looks like Method 7 has completely changed their model names since 2019 and they have a lot of different choices. I'm also looking at flying eyes - they have a two yellow tinted options with arout 85% VLT that might be good choices? They magnetic clip on for their prescription frames which are really nifty except I doubt they'll make the clip ons with those tints.
    https://flyingeyesoptics.com/our-lenses/
    Looking at the YLW or AMB lenses there.
    8,188
    I’ve spent most of my life on skis and snowmachines. There’s no magic lens for flat light. Spend your money on badass lights to illuminate what you can’t see.
    Likes Narwhal, Randyk, NunavutPA-12 liked this post
    4,416
    Many of us have obviously spent time in flat light. I'm not a skier but assume at their speed vision is critical. I have tried various lenses (for skiers, snowmachiners, and prescription) and settled for everyday use on brown photochromatic prescription lenses. Not the best however. If I were curious I'd source several and test in flat light. And not everyone sees the same world. Ask a dog.
    Feb 2009
    67.8N,115.1W CYCO Canada
    1,068
    As pointed out earlier, a very bright LED landing light, mounted as low as possible, is a big help in creating shadows so you will (might?) be able to see the drifts and the surface.
    Nevertheless, we have enough dangers when flying in remote places during very cold weather. Enough that I choose not to do it anymore. And the dangers can be present not only when landing but also when in-flight in an area without much contrast on the ground. That horizon can disappear suddenly and without warning. Now you're IFR!
    Often the best and safest option is to stay home.
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,247
    I carry "regular" sunglasses, plus some amber tinted ones when ski flying. It is common for me to switch them off back and forth, or not use any, several times during a flight, as there is no magic bullet for flat light. I'm a snowboarder, a 73 year old boarder, and I'm at the point that when it's a poor definition day I don't go, or if it turns that way after I'm on the mountain, I leave. Hitting bumps I can't see sucks, as does thinking I'm stopped but actually still moving, or the reverse. I've never snowmobiled, but I recently very quickly learned, after I started riding my electric snowbike, that decent viz is critical to that activity also. Getting whited out just isn't any fun it seems.
    Likes stid2677, Bill Rusk, 180Marty liked this post
    Meanwhile,...
    5,583
    The Orange Serengeti polarized lenses are amazing, but you have to pull them off before sun starts to pop out.
  1. Flat Light Friday
    By Henny in forum Cafe Supercub
    Last Post: 03-25-2012, 08:48 PM
  2. PA-12 Jig Recomendations
    By KJC in forum Cafe Supercub
    Last Post: 04-29-2009, 03:22 PM
  3. Landing Light Bay, Fixture, Plates -- Always Flat Black?
    By James L. Smith in forum Cafe Supercub
    Last Post: 09-11-2006, 09:28 AM
Tags for this Thread
