Results 1 to 15 of 15
Thread: N strut question
    Mar 2017
    34
    N strut question
    I'm in the process of rebuilding my PA11 wings. I have them partially assembled and am at the point of trammelling them. When done with this process I have a slight bow in the spar between the number 3 compression strut and the N strut. It is visible when sighting down the spar and the string line confirms it. After much head scratching and triple checking all the trammelling points and measurements I didn't find any errors. I finally disassembled the diagonal on the N strut and now have perfectly straight and parallel spars. The hole on the N strut diagonal is now about 3/16 of an inch out of alignment. I was wondering if anyone has had this experience and if so how the problem was dealt with.
    Dan
    Tango Cub's Avatar
    Sep 2005
    Duluth MN
    142
    [QUOTE=kodiakcub;839452]I'm in the process of rebuilding my PA11 wings. I have them partially assembled and am at the point of trammelling them. When done with this process I have a slight bow in the spar between the number 3 compression strut and the N strut. It is visible when sighting down the spar and the string line confirms it. After much head scratching and triple checking all the trammelling points and measurements I didn't find any errors. I finally disassembled the diagonal on the N strut and now have perfectly straight and parallel spars. The hole on the N strut diagonal is now about 3/16 of an inch out of alignment. I was wondering if anyone has had this experience and if so how the problem was dealt with.
    Try flipping the N strut over it looks like it can be installed either way but it has to be installed the one way.
    Bryan
    Life is not measured by the number of breaths you take but by the times that take your breath away
    Mar 2017
    34
    I installed the strut in accordance with the wing drawing. It is also the same as removed .
    Dan
    Likes grbreen liked this post
    coxcub's Avatar
    Apr 2004
    Devon, England
    298
    I had an identical problem - bowed spars when trammelling - after much head scratching I found the lower member of the N strut was 1/8" too long. It had been replaced at some time in a former life with an upper member. the lower one allows for the drag wire fittings.
    22,480
    One leg of the N strut is longer than the other. The short leg goes between the two wire pulls. Had a Super Cub out of Mexico that was assembled that way.
    Thanks tedwaltman1 thanked for this post
    supercrow's Avatar
    Dec 2008
    654
    I also found one like that on John Meades S. cub some years ago during an annual. It was corrected when they covered the wings not long after. That one had a cable rubbing so wasn't hard to find.
    22,480
    Quote Originally Posted by supercrow View Post
    I remember that, the N was inverted.
    supercrow's Avatar
    Dec 2008
    654
    Yes it was.
    Likes mixer liked this post
    RaisedByWolves's Avatar
    Feb 2005
    4,920
    Another good reason to hang wings and control cables before covering.
    Mar 2017
    34
    I've checked the N strut installation and it all seems good. The strut is installed correctly by the wing drawing 10625 and I have the short leg on top between the wire pulls. Would anyone have the dimensions for the diagonal tube hole centers? This wing had some hidden damage I found when disassembling and I am not sure if this N strut is correct.
    Dan
    Thanks Randy Wilson thanked for this post
    22,480
    What dimension do you need?
    Mar 2017
    34
    The distance between the hole centers on the diagonal tube and the overall length of the lower (long) tube.
    Dan
    Mar 2017
    34
ID:	64385 Im having alot of fit issues for basically a new wing. First the N strut now the center aileron hinge doesn't seem to fit. It is hitting the wing attach fitting before the spar. Am I missing something in this installation? After doing some quick measurements I don't see any real differences between the old spar and the new.
    Dan
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    442
    Don't know if your wing and a pa-18 wing are the same, but Bill Rusk mentioned this in his thread about building a Javron wing. Check post #32 in his topic.
    https://www.supercub.org/forum/showt...l=1#post756644
    Thanks kodiakcub thanked for this post
    Mar 2017
    34
    Quote Originally Posted by flybynite View Post
    Thank you that was exactly what I was looking for.
    Dan
  1. Question on strut fork bolts
    By Cooley in forum Cafe Supercub
    Last Post: 09-08-2021, 04:25 PM
  2. Strut question?
    By supercub in forum Cafe Supercub
    Last Post: 09-22-2019, 12:47 AM
  3. Strut question??
    By Klondiker in forum Cafe Supercub
    Last Post: 06-05-2013, 11:13 AM
  4. wing strut question
    By Dunn in forum Cafe Supercub
    Last Post: 01-08-2010, 03:50 PM
