wadeholmes
Bend, OR
Howdy all. I've been a lurker and consumer of your collective wisdom on the forum for a while, but I'm coming down the home stretch now and am hoping for a few tips or last acts of advise before I do something I can't uncover. I'll add photos where appropriate, any feedback and ideas welcome.
Here's a brief intro to the project:
- It's a certified 1955 PA-18A-150 with an O320-A2A (lower-mid time, fresh teardown complete, rebuilt mags, other engine upgrades (starter, spin-on oil), hotrod exhaust
- fuse that came on the plane was a PA-18, got a well-repaired ag frame to return it to proper 18-A +mods (and clean books)
- fuse mods are L21 windows, welded seatbelt attach, reverse dogleg, ext baggage, rear +structure, elevator zerk, round formers, tank baggage door, headerless fuel
- under seat battery and redo on the electrical, nothing fancy on panel or nav
- wings: replaced all 4 spars, most ribs, lift points, tie points (no 2000lb kit), light kit both wings, high tension pullies, new cables and skins. Yakima AS is covering wings.
- gear is the 6" extended, 6-bolt wheels, cubcrafters master cylinder upgrade, safety cables, baby bush on the back, adjustable brake links
In terms of resources, working off the northland drawings, maintenance and service manual, parts catalog and L21 guide, plus the A&P/AI overseeing my work-- and the forum, thank you for all the great help. I also have a lot of good parts that I've replaced (generator, battery box, baggage doors, etc), so ping me for parts if anything comes to mind.
Couple questions right out of the gate I'm interested in:
(1) the A-model fuse had a metal belly and has tabs. I like the idea of metal because I'm in the high desert (central oregon) and sage brush and rock has brutalized the belly and feathers on my C120, it seems smart. Anybody have any compromise solutions they like or threads that I should read (or again) such as 50/50 or plans for the right bends?
(2) the fuse didn't come with side stringers, but it has tabs (of uneven length). I can't find for the life of me the distance the side stringer (14979-00) should be from the upright tubes, anybody have that from memory or a reference to point me at?
(3) if you have a top/tank baggage door, did you lexan or fabric it - and any pointers on seal (it's gonna leak) techniques that worked well?
Thanks in advance and I look forward to ideas and encouragement to get this two-year in the making project flying soon.
Wade
Wade
